查看: 3119|回复: 4
[每日一码] 射线法判断点是否在曲线内(C#版)
已领礼包: 13个
发表于 2017-8-12 00:27:14 | 显示全部楼层 |阅读模式
[C#] 纯文本查看 复制代码
enum IncidenceType
    kIncidenceToLeft = 0,
    kIncidenceToRight,
    kIncidenceToFront,
    kIncidenceUnknown
IncidenceType CurveIncidence(Curve curve, double param, Vector3d dir, Vector3d normal)
    Vector3d deriv1 = curve.GetFirstDerivative(param);
    if(deriv1.IsParallelTo(dir))
        // need second degree analysis
        Vector3d deriv2 = curve.GetSecondDerivative(param);
        if( deriv2.IsZeroLength() || deriv2.IsParallelTo(dir))
            return IncidenceType.kIncidenceToFront;
        else
            if(deriv2.CrossProduct(dir).DotProduct(normal) < 0)
                return IncidenceType.kIncidenceToRight;
            else
                return IncidenceType.kIncidenceToLeft;
    if(deriv1.CrossProduct(dir).DotProduct(normal) < 0)
    else
bool IsInsideCurve(Curve curve, Point3d testPt)
    if(!curve.Closed)
        // cannot be inside
        return false;
    Point3d ptOnCurve = curve.GetClosestPointTo(testPt, false);
    if( testPt == ptOnCurve)
        return true;
    if(!curve.IsPlanar)
        return false;
    // check its planar
    Plane plane = curve.GetPlane();
    // make the test ray from the plane
    double epsilon = 2e-6; // ( trust me on this )
    Point3dCollection IntersectionPoints = new Point3dCollection();
    Vector3d normal = plane.Normal;
    Vector3d testVector = normal.GetPerpendicularVector();
    using (Ray ray = new Ray())
        ray.BasePoint = testPt;
        int nGlancingHits = 0, numberOfInters = 0;
        bool bRetryWithOtherRayDirection;
        do
            bRetryWithOtherRayDirection = false;
            IntersectionPoints.Clear();
            ray.UnitDir = testVector;
            // fire the ray at the curve
            curve.IntersectWith(ray,
                Intersect.OnBothOperands,
                IntersectionPoints,
                IntPtr.Zero,
                IntPtr.Zero);
            numberOfInters = IntersectionPoints.Count;
            if (numberOfInters == 0)
                return false;
            nGlancingHits = 0;
            for (int i = 0; i < IntersectionPoints.Count; ++i)
                double hitParam;
                try
                    //This try/catch block circumvents an issue with GetParameterAtPoint API
                    hitParam = curve.GetParameterAtPoint(IntersectionPoints[i]);
                catch
                    bRetryWithOtherRayDirection = true;
                    testVector = testVector.RotateBy(5.0 * Math.PI / 180.0, normal);
                    break;
                double inParam = hitParam - epsilon;
                double outParam = hitParam + epsilon;
                //Loop back inside the curve if param is falling outside of range
                if (inParam < curve.StartParam)
                    inParam = curve.EndParam - epsilon + (curve.StartParam - inParam);
                if (outParam > curve.EndParam)
                    outParam = curve.StartParam + epsilon + (curve.EndParam - outParam);
                IncidenceType inIncidence = CurveIncidence(curve, inParam, testVector, normal);
                IncidenceType outIncidence = CurveIncidence(curve, outParam, testVector, normal);
                if (inIncidence == IncidenceType.kIncidenceToFront || outIncidence == IncidenceType.kIncidenceToFront)
                    break;
                if ((inIncidence == IncidenceType.kIncidenceToRight && outIncidence == IncidenceType.kIncidenceToLeft) ||
                    (inIncidence == IncidenceType.kIncidenceToLeft && outIncidence == IncidenceType.kIncidenceToRight))
                    nGlancingHits++;
        while (bRetryWithOtherRayDirection);
        return ((numberOfInters + nGlancingHits) % 2 == 1);
[C#] 纯文本查看 复制代码
[CommandMethod("TestIsInsideCurve")]
public void TestIsInsideCurve()
    Document doc = Application.DocumentManager.MdiActiveDocument;
    Database db = doc.Database;
    Editor ed = doc.Editor;
    PromptEntityOptions peo = new PromptEntityOptions("\nSelect a Curve: ");
    peo.SetRejectMessage("\nInvalid selection...");
    peo.AddAllowedClass(typeof(Curve), false);
    PromptEntityResult per = ed.GetEntity(peo);
    if (per.Status != PromptStatus.OK)
        return;
    PromptPointResult ppr = ed.GetPoint("\nPick a point");
    if (ppr.Status != PromptStatus.OK)
        return;
    using (Transaction Tx = db.TransactionManager.StartTransaction())
        Curve curve = Tx.GetObject(per.ObjectId, OpenMode.ForRead) as Curve;
        bool res = IsInsideCurve(curve, ppr.Value);
        ed.WriteMessage("\nInside: " + res.ToString());
评分
参与人数 1D豆 +5 收起 理由
gdfyhao + 5 很给力!经验;技术要点;资料分享奖!
查看全部评分
发表于 2018-5-11 11:38:31 | 显示全部楼层
很酷呀。。。
发表于 2020-5-30 10:17:37 | 显示全部楼层
好好!!!!学习了谢谢!!!
已领礼包: 82个
发表于 2020-6-6 16:00:23 | 显示全部楼层
可以可以
已领礼包: 7个
发表于 2020-10-27 18:22:51 | 显示全部楼层
看起来像是用射线法计算的,学习一下
GMT+8, 2026-10-12 20:34 , Processed in 0.407363 second(s), 37 queries , Gzip On.
