查看: 1188|回复: 4
[ARX程序]:生成地形图等高线的程序
发表于 2003-10-17 21:56:54 | 显示全部楼层 |阅读模式
如何去生成等高线,可能很多朋友不太清楚,我现有一生成等高线的程序,主要代码如下,具体见附件!!!
int _map_draw()
  struct resbuf rb;  /*供存取AutoCAD系统变量之用*/
  char str[20],map_dat[320];
  int i,pos,c,error_flag=0,uds,re_num;
  ads_real equal_val,ang;
  struct resbuf *result;
  char *token;
  pt_temp0[Z]=pt_temp1[Z]=0.0;
  if(tbl_check("STYLE","MAP_TXT")==RTERROR) {
    acedCommand(RTSTR,"STYLE",RTSTR,"MAP_TXT",RTSTR,"TIMES.TTF",
      RTSTR,"0",RTSTR,"1.0",RTSTR,"",RTSTR,"",RTSTR,"",0);
    sprintf(tbuf,"字体样式MAP_TXT被创建.");
    acedAlert(tbuf);
  if(tbl_check("LAYER","MAP_OUTLINE")==RTERROR) {
      layer_do("M","MAP_OUTLINE");
  if(tbl_check("LAYER","MAP_TEXT")==RTERROR) {
      layer_do("M","MAP_TEXT");
      layer_edit("C","RED","MAP_TEXT");
  if((result=acutNewRb(RTSTR))==NULL) {
    acdbFail("\nUnable to allocate buffer.");
    return RTERROR;
  if((result->resval.rstring=(char *)malloc(80))==NULL) {
    acdbFail("\nUnable to allocate string.");
    return RTERROR;
  if(acedGetFileD("选择已有的地形图数据文件",NULL,"MAP",2,result)
    !=RTNORM) {
    acutRelRb(result);
    return RTERROR;
  strcpy(map_name,result->resval.rstring);
  acutRelRb(result);
  acedGetVar("userr1",&rb);  /*从系统变量userr1获取当前使用的比例值*/
  scale=rb.resval.rreal;
  if(scale==0.0) strcpy(tbuf,"1:1");
  else {
    if(scale<1.0) sprintf(tbuf,"1:%g",1.0/scale);
    else sprintf(tbuf,"%g:1",scale);
  sprintf(tbuf1,"\n请输入比例值<%s>:",tbuf);
  if(acedGetString(1,tbuf1,str)==RTCAN) return RTERROR;
  if(str[0]==EOS) strcpy(str,tbuf);
  scale=atof(str);      /*获取scale值*/
  token=strchr(str,(int)':');
  if(token==NULL) {
    acutPrintf("\n比例输入有误.");
    return RTERROR;
  *token++;
  if(atof(token)==0) {
    return RTERROR;
  scale/=atof(token);    /*获取用户输入值,送scale变量*/
  acutPrintf("\n ");
  acutPrintf("\n是否要对所生成的等高线进行光顺?");
  acutPrintf("\n0=不进行光顺处理; 1=进行光顺处理<%d>:",pedit_flag);
  Int_input2(4,NULL,&pedit_flag,pedit_flag<2);
  layer_do("S","MAP_OUTLINE");
  if((fp=fopen(map_name,"rb"))==NULL) {
    sprintf(tbuf,"文件 %s 不能打开!",map_name);
    acedAlert(tbuf);
    return RTERROR;
  map_dat[0]=EOS;
  error_flag=0;
  while((c=getc(fp))!=EOF) {
    if(c==13) {
      if((map_dat[0]>='0'&&map_dat[0]<='9')
          ||map_dat[0]=='+'||map_dat[0]=='-') {
        equal_val=atof(map_dat);      /*获取scale值*/
        token=strchr(map_dat,(int)',');
        if(token==NULL) {
          acutPrintf("\n数据文件格式有误.");
          error_flag=1;
          break;
        *token++;
        pos=atoi(token);    /*获取用户输入值,送scale变量*/
        token=strchr(token,(int)':');
        if(token==NULL) {
          error_flag=1;
          break;
        *token++;
        i=0;
        acedCommand(RTSTR,"PLINE",RTNONE);
        for(;;) {
          if(i>0&&i<abs(pos)) {
            Cpoint(pt_temp0,pt_temp1);
          pt_temp1[X]=(atof(token))*scale;
          token=strchr(token,(int)',');
          if(token==NULL) {
            error_flag=1;
            break;
          *token++;
          pt_temp1[Y]=(atof(token))*scale;
          token=strchr(token,(int)';');
          i++;
          if(i==abs(pos)) {
            pt_temp0[X]=(pt_temp0[X]+pt_temp1[X])/2;
            pt_temp0[Y]=(pt_temp0[Y]+pt_temp1[Y])/2;
            ang=acutAngle(pt_temp0,pt_temp1);
            if(pos<0) ang+=PI;
          acedCommand(RTPOINT,pt_temp1,RTNONE);
          if(token==NULL) break;
          *token++;
        acedCommand(0);
        if(error_flag==0&&pedit_flag==1) {
          acedCommand (RTSTR,"PEDIT",RTSTR,"L",RTSTR,"F",RTSTR,"",0);
        if(error_flag==1) break;
        layer_do("S","MAP_TEXT");
        sprintf(tbuf,"%g",equal_val);
        acedCommand(RTSTR,"TEXT",RTSTR,"BC",RTPOINT,pt_temp0,
            RTREAL,3.2*scale,RTREAL,ang*180/PI,RTSTR,tbuf,0);
      map_dat[0]=EOS;
    else {
      if(c!=10) sprintf(map_dat,"%s%c",map_dat,c);
  fclose(fp);
  acedCommand(RTSTR,"ZOOM",RTSTR,"ALL",0);
  rb.restype=RTREAL;
  rb.resval.rreal=scale;
  acedSetVar("userr1",&rb);     /*将新的比例值送userr1系统变量保存*/
  return RTNORM;
发表于 2004-8-9 16:28:58 | 显示全部楼层
附件在那里?
发表于 2004-8-14 00:11:06 | 显示全部楼层
把附件传上来看看啊。
发表于 2005-2-23 15:34:13 | 显示全部楼层
是否有实例
发表于 2005-2-25 12:11:22 | 显示全部楼层
想要附件.......wxj810406@163.com
253楼主....
GMT+8, 2026-11-6 05:13 , Processed in 0.461451 second(s), 41 queries , Gzip On.
