查看: 3838|回复: 38
[求助]:怎样快速给已画图形分层?
发表于 2003-10-30 15:48:04 | 显示全部楼层 |阅读模式
怎样快速给已画图形分层?
发表于 2003-10-30 15:58:19 | 显示全部楼层
自动建层的LISP
(defun c:jc()
(command "layer" "m" "t100" "c" "7" "" "")
(command "layer" "m" "kzd" "c" "6" "" "")
(command "layer" "m" "t200" "c" "6" "" "")
(command "layer" "m" "t300" "c" "6" "" "")
(command "layer" "m" "t400" "c" "1" "" "")
(command "layer" "m" "t500" "c" "5" "" "")
(command "layer" "m" "t501" "c" "7" "" "")
(command "layer" "m" "t600" "c" "4" "" "")
(command "layer" "m" "t700" "c" "2" "" "")
(command "layer" "m" "t800" "c" "5" "" "")
(command "layer" "m" "t801" "c" "7" "" "")
(command "layer" "m" "yzh" "c" "3" "" "")
(command "layer" "m" "gxyz" "c" "5" "" "")
(command "layer" "m" "zmd" "c" "6" "" "")
(command "layer" "m" "dlss" "c" "30" "" "")
(command "layer" "m" "jj" "c" "2" "" "")
(command "layer" "m" "sx" "c" "4" "" "")
(command "layer" "m" "dmtz" "c" "1" "" "")
(command "layer" "m" "gcd" "c" "1" "" "")
(command "layer" "m" "jqx" "c" "1" "" "")
(command "layer" "m" "zb" "c" "3" "" "")
(command "layer" "m" "tk" "c" "7" "" "")
发表于 2003-10-30 16:02:26 | 显示全部楼层
Re: [求助]:怎样快速给已画图形分层?
最初由 yzhmyyy 发布
[B]怎样快速给已画图形分层? [/B]
也不知道你要怎么分层,感觉可能没有什么特别有效的办法,最好的做法就是在做图的时候就将实体画在不同的层上。
发表于 2003-10-30 16:09:36 | 显示全部楼层
楼上说得对
发表于 2003-10-30 17:00:17 | 显示全部楼层
对可以按对象的特征决定图层名的行业专业就好办啦,这些特征如颜色、线型、线宽、文字、尺寸标注等。编个程序,让它按这些特征自动建层并归到层内。不能按对象特征分类的话好像没有什么好办法。
发表于 2003-10-30 22:29:47 | 显示全部楼层
楼主啊~你的题目有问题啊~——如果是修改别人的图不怪你,但属于你自己制作的图提这个要求,那么俺就要说:你本不应该提出这样的问题,因为你在养成一种不好的习惯——图层应该是在还没有制图之前确定好的~~
当然你的问题不是没有办法解决,很简单,在解决之前你还是得把你认为需要分的层及与层相关得特性建好,然后把所有的层比如先在画面上都画一个对象,然后再用“刷子功”——这对你的题俺认为是最快的:)不知你理解没有,俺可是不会盲打的,但还是敲了这些“败字”:(
发表于 2003-10-30 23:07:23 | 显示全部楼层
这是哈哈说得最准确的一次,养成良好的习惯最重要。
不过,哈哈还是有错误,你的“刷子功”不按下图设置而用ACAD缺省设置,这么一刷还不乱套?俺差一点又上当。
即便按下图设置了,实际还有问题,如果干脆所有对象的颜色线型都不随层,那倒好办,有随层的问题就来了。原图层定义为红色,新图层定义为黄色,这一刷不就红色变成黄色啦?
发表于 2003-10-30 23:15:18 | 显示全部楼层
为什么不在绘图之前就分好层?这样做会节约很多时间啊!
磨刀不误砍柴工!
发表于 2003-10-30 23:30:32 | 显示全部楼层
柔柔是在捣乱:)看看俺的演示吧
发表于 2003-10-30 23:35:54 | 显示全部楼层
自己来证明自己错误,楼主的要求是画好了的图重新分图层,或分开或合并,但前提是只改图层不更改对象的其他特征(如颜色、线型)。
发表于 2003-10-30 23:39:20 | 显示全部楼层
最初由 柔柔 发布
[B]自己来证明自己错误,楼主的要求是画好了的图重新分图层,或分开或合并,但前提是不更改对象的特征。 [/B]
你虽然在“捣乱”俺,其实是对俺的补充~斑竹也给你大洋了,你还小器:)但是你是错的,凡需要的图层同样也设置好需要的其他特性,刷子功的勾就得相应勾上!
发表于 2003-10-30 23:42:01 | 显示全部楼层
我认为这样也可以:
在这个图形里按你要求建好需要的图层,然后逐一选中各相关对象,点属性命令,在属性对话窗口的图层栏选你刚建的图层名称就成。
如你图形复杂,可逐步关闭确定的图层,这样以后的对象选起来会方便些。
但这都是不得以而为之,最好的办法还是作图前建好图层。
发表于 2003-10-30 23:43:36 | 显示全部楼层
你怎么刚知道啊?我的“捣乱”就是补充,当然更重要的是纠错,让你别误导俺们新手。呵呵
本柔柔比较大方,如果层名可以设成如下格式的话,我倒可以提供程序代码:
颜色代号-线型名
文字
尺寸
这些都是对象特征,让程序自动获得。
发表于 2003-10-30 23:50:29 | 显示全部楼层
最初由 柔柔 发布
[B]你怎么刚知道啊?我的“捣乱”就是补充,当然更重要的是纠错,让你别误导俺们新手。呵呵 [/B]
还得意呢,俺就是说必须相应勾上!:)前提是在设置需要的层的同时,必须把线形颜色也按需要设定~这在俺最初的演示(现又重新编辑了Flash)里没有表达,这里补上就算是柔柔补的:)
发表于 2003-10-30 23:54:53 | 显示全部楼层
我认为你们二位的方法都不如我12楼的方法!
GMT+8, 2026-10-18 05:27 , Processed in 0.517326 second(s), 61 queries , Gzip On.
