查看: 1159|回复: 0
[LISP程序]:多义线改厚度
发表于 2002-7-28 21:05:29 | 显示全部楼层 |阅读模式
由mf7000的发帖引申,参考:http://www.xdcad.net/forum/showt ... tid=49258#post49258
做了一个lsp,另一种写法。
增加 M-厚度反相/ <拉伸到指定点高度>,对多个不同z高度多义线拉伸厚度到同一高度有效(此时厚度不同)
  1.   [FONT=courier new]
  2. ;;plth多义线拉伸厚度v1.0-----------www.xdcad.net--dreamsky.lxx.梦断江南.2002.7
  3. (defun c:plth ();( / ptz ss i pt1 pt2 thk ent i entl lpz lpth)
  4.   (princ "\n plth多义线拉伸厚度v1.0------------www.xdcad.net--dreamsky.lxx.梦断江南.2002.7")
  5.   (initget "  X Y Z D M " )
  6.   (setq ptz (getstring "\n X-高度按两点x差值/Y/Z/D-距离定拉伸高度/M-厚度反相/<拉伸到指定点高度>:")
  7.          ss (ssget '((0 . "*LINE,ARC,CIRCLE,ELLIPSE")))
  8.          i 0)
  9. (cond
  10.    ((wcmatch ptz "[xXyYzZdD]")
  11.     (setq pt1 (getpoint "\n第一点:")
  12.           pt2 (getpoint pt1 "\n第二点:")
  13.           thk (cond ((wcmatch ptz "[xX]")(- (car pt2)(car pt1)) )
  14.                     ((wcmatch ptz "[yY]")(- (cadr pt2)(cadr pt1)) )
  15.                     ((wcmatch ptz "[zZ]")(- (caddr pt2)(caddr pt1)) )
  16.                     ((wcmatch ptz "[dD]")(distance pt1 pt2) )
  17.               )
  18.     );end setq
  19.     (if thk (COMMAND "_.CHPROP" ss "" "T" thk ""))
  20.    );end case1
  21.   (T
  22.    (if (= "" ptz) (setq ptz (caddr (getpoint "\n指定高度点:"))))
  23.    (repeat (sslength ss)
  24.     (setq ent (ssname ss i)
  25.           i (1+ i)
  26.           entl (entget ent)
  27.           lpz (cdr (assoc 38 entl))
  28.           lpth (cdr (assoc 39 entl)))
  29.     (cond
  30.       ((or (= "m" ptz)(= "M" ptz))(setq lpth (- 0 lpth)))
  31.       (t (setq lpth (- ptz lpz)))
  32.     );end cond
  33.     (setq entl2 (subst (cons 39 lpth)(assoc 39 entl) entl))
  34.     (entmod entl2)
  35.    );end repeat
  36.   );;end case2
  37. );;end cond
  38. (princ)
  39. )
  40.   [/FONT]
GMT+8, 2026-11-3 09:39 , Processed in 0.459014 second(s), 32 queries , Gzip On.
