查看: 875|回复: 2
[讨论]:请大大虾进来帮我看看!!!!!!!!!
发表于 2003-11-10 22:42:39 | 显示全部楼层 |阅读模式
如何删除实体上的扩展记录?????????搞的我头都大了!!!请各位大虾帮帮我吧!!!!!
发表于 2003-11-12 12:03:27 | 显示全部楼层
virtual Acad::ErrorStatus
setXData(
    const resbuf* xdata);
To remove an appName (and its xdata) from an object, just use a resbuf with restype == 1001, resval == <the appname string> and no data resbufs following it (that is, either its rbnext == NULL or the next resbuf is another 1001)
 楼主| 发表于 2003-11-12 21:41:07 | 显示全部楼层
我加是extensionDictionary
不是XDATA
GMT+8, 2026-11-6 05:52 , Processed in 0.506598 second(s), 36 queries , Gzip On.
