[求助]:如何统一字体
发表于 2006-5-20 02:57:51 | 显示全部楼层
Re: [求助]:如何统一字体
最初由 ¥夜悸孤枕¥ 发布
[B]如果在一副图里有很多的字体样式 我想把它都用一种统一 该怎么做啊  删又删不了 用字体属性改就改动了字体 可是它还是有很多的样式 我想把他们都用“样式名”为宋体 字体名 为宋体 统一该怎么做? 谢谢 [/B]
我这个是用来把所有字体(以下所包含的字体,没有的可以自己加)都转换成txt.shx,hztxt.shx字体的一个Lisp程序,楼主可以用来参考.
(DEFUN C:-st ()
       (command "-style" "hztxt" "txt.shx,hztxt.shx" "" "" "" "" "" "")
       (command "-style" "chian" "txt.shx,hztxt.shx" "" "" "" "" "" "")
       (command "-style" "dim_font" "txt.shx,hztxt.shx" "" "" "" "" "" "")
       (command "-style" "1" "txt.shx,hztxt.shx" "" "" "" "" "" "")
       (command "-style" "ht" "txt.shx,hztxt.shx" "" "" "" "" "" "")
       (command "-style" "hz" "txt.shx,hztxt.shx" "" "" "" "" "" "")
       (command "-style" "romand" "txt.shx,hztxt.shx" "" "" "" "" "" "")
       (command "-style" "standard" "txt.shx,hztxt.shx" "" "" "" "" "" "")
       (command "-style" "yy" "txt.shx,hztxt.shx" "" "" "" "" "" "")
       (command "-style" "ro" "txt.shx,hztxt.shx" "" "" "" "" "" "")
       (command "-style" "style1" "txt.shx,hztxt.shx" "" "" "" "" "" "")
       (command "-style" "-黑体" "txt.shx,hztxt.shx" "" "" "" "" "" "")
       (command "-style" "simplex" "txt.shx,hztxt.shx" "" "" "" "" "" "")
       (command "-style" "h1" "txt.shx,hztxt.shx" "" "" "" "" "" "")
       (command "-style" "youyuan" "txt.shx,hztxt.shx" "" "" "" "" "" "")
       (command "-style" "kt64f" "txt.shx,hztxt.shx" "" "" "" "" "" "")
       (command "-style" "lushu" "txt.shx,hztxt.shx" "" "" "" "" "" "")
       (command "-style" "kaiti" "txt.shx,hztxt.shx" "" "" "" "" "" "")
       (command "-style" "meihei" "txt.shx,hztxt.shx" "" "" "" "" "" "")
       (command "-style" "songti" "txt.shx,hztxt.shx" "" "" "" "" "" "")
       (command "-style" "zongyi" "txt.shx,hztxt.shx" "" "" "" "" "" "")
       (command "-style" "宋体" "txt.shx,hztxt.shx" "" "" "" "" "" "")
       (command "-style" "_simplex" "txt.shx,hztxt.shx" "" "" "" "" "" "")
       (command "-style" "att" "txt.shx,hztxt.shx" "" "" "" "" "" "")
       (command "-style" "dim" "txt.shx,hztxt.shx" "" "" "" "" "" "")
       (command "-style" "黑体" "txt.shx,hztxt.shx" "" "" "" "" "" "")
       (command "-style" "楷体" "txt.shx,hztxt.shx" "" "" "" "" "" "")
       (command "-style" "幼圆" "txt.shx,hztxt.shx" "" "" "" "" "" "")
       (command "-style" "华文" "txt.shx,hztxt.shx" "" "" "" "" "" "")
       (command "-style" "style2" "txt.shx,hztxt.shx" "" "" "" "" "" "")
       (command "-style" "style3" "txt.shx,hztxt.shx" "" "" "" "" "" "")
       (command "-style" "华文中宋" "txt.shx,hztxt.shx" "" "" "" "" "" "")
       (command "-style" "2" "txt.shx,hztxt.shx" "" "" "" "" "" "")
       (command "-style" "3" "txt.shx,hztxt.shx" "" "" "" "" "" "")
       (command "-style" "text" "txt.shx,hztxt.shx" "" "" "" "" "" "")
       (command "-style" "text1" "txt.shx,hztxt.shx" "" "" "" "" "" "")
       (command "-style" "text2" "txt.shx,hztxt.shx" "" "" "" "" "" "")
       (command "-style" "dim1" "txt.shx,hztxt.shx" "" "" "" "" "" "")
       (command "-style" "dim2" "txt.shx,hztxt.shx" "" "" "" "" "" "")
       (command "-style" "_ht64f" "txt.shx,hztxt.shx" "" "" "" "" "" "")
       (command "-style" "_hzls" "txt.shx,hztxt.shx" "" "" "" "" "" "")
       (command "-style" "_txt" "txt.shx,hztxt.shx" "" "" "" "" "" "")
       (command "-style" "4" "txt.shx,hztxt.shx" "" "" "" "" "" "")
       (command "-style" "5" "txt.shx,hztxt.shx" "" "" "" "" "" "")
       (command "-style" "6" "txt.shx,hztxt.shx" "" "" "" "" "" "")
       (command "-style" "_hzdx" "txt.shx,hztxt.shx" "" "" "" "" "" "")
       (command "-style" "_cibt____" "txt.shx,hztxt.shx" "" "" "" "" "" "")
       (command "-style" "comb" "txt.shx,hztxt.shx" "" "" "" "" "" "")
       (command "-style" "middle" "txt.shx,hztxt.shx" "" "" "" "" "" "")
       (command "-style" "_fds" "txt.shx,hztxt.shx" "" "" "" "" "" "")
       (command "-style" "_romanc" "txt.shx,hztxt.shx" "" "" "" "" "" "")
       (command "-style" "cg" "txt.shx,hztxt.shx" "" "" "" "" "" "")
       (command "-style" "fs1" "txt.shx,hztxt.shx" "" "" "" "" "" "")
       (command "-style" "_fs1" "txt.shx,hztxt.shx" "" "" "" "" "" "")
       (command "-style" "std" "txt.shx,hztxt.shx" "" "" "" "" "" "")
       (command "-style" "_fsj" "txt.shx,hztxt.shx" "" "" "" "" "" "")
       (command "-style" "fs" "txt.shx,hztxt.shx" "" "" "" "" "" "")
       (command "-style" "st" "txt.shx,hztxt.shx" "" "" "" "" "" "")
       (command "-style" "LP1" "txt.shx,hztxt.shx" "" "" "" "" "" "")
       (command "-style" "ROMANT" "txt.shx,hztxt.shx" "" "" "" "" "" "")
       (command "-style" "lp2" "txt.shx,hztxt.shx" "" "" "" "" "" "")
       (command "-style" "_HZTXT" "txt.shx,hztxt.shx" "" "" "" "" "" "")
       (command "-style" "_COMPLEX" "txt.shx,hztxt.shx" "" "" "" "" "" "")
       (command "-style" "complex" "txt.shx,hztxt.shx" "" "" "" "" "" "")
       (command "purge" "a" "*" "n")
       (princ "\n 字体转换成功!")
(PRINC))
发表于 2006-5-20 08:16:45 | 显示全部楼层
楼上很多方法,学习学习,用flash讲解的是不是只有2007和2006才能用呀,还有楼上的是不是要把经常用到的所有字体都列进去吗?
发表于 2006-5-20 13:58:22 | 显示全部楼层
好东东
发表于 2006-10-13 16:24:18 | 显示全部楼层
四楼太帅了
实在是高
发表于 2006-10-14 07:53:23 | 显示全部楼层
最初由 egos 发布
[B]standard样式可用命令行-purge清除掉(非图形界面purge)
但你要保证确实没用这个样式 [/B]
默认的样式应该不好清理吧。
发表于 2006-10-14 21:35:48 | 显示全部楼层
这个FLASH做得好,一下让我解决了一个困扰很久的问题.谢谢.
GMT+8, 2026-10-19 11:57 , Processed in 0.453267 second(s), 36 queries , Gzip On.
