- UID
- 14
- 积分
- 8265
- 精华
- 贡献
- 威望
- 活跃度
- D豆
- 在线时间
- 小时
- 注册时间
- 2002-1-4
- 最后登录
- 1970-1-1
经典VBS代码
注销/重起/关闭本地Windows NT/2000 计算机
Sub ShutDown()
Dim Connection, WQL, SystemClass, System
Get connection To local wmi
Set Connection = GetObject("winmgmts:root\cimv2")
Get Win32_OperatingSystem objects - only one object In the collection
WQL = "Select Name From Win32_OperatingSystem"
Set SystemClass = Connection.ExecQuery(WQL)
Get one system object
I think there is no way To get the object using URL?
For Each System In SystemClass
System.Win32ShutDown (2)
Next
End Sub
注销/重起/关闭远程Windows NT/2000 计算机
Sub ShutDownEx(Server, User, Password) Dim Connection, WQL, SystemClass, System Get connection To remote wmi Dim Locator Set Locator = CreateObject("WbemScripting.SWbemLocator") Set Connection = Locator.ConnectServer(Server, "root\cimv2", User, Password) Get Win32_OperatingSystem objects - only one object In the collection WQL = "Select Name From Win32_OperatingSystem" Set SystemClass = Connection.ExecQuery(WQL) Get one system object I think there is no way To get the object using URL? For Each System In SystemClass System.Win32ShutDown (2) NextEnd Sub
上面两段代码都用到了WMI中Win32_OperationSystem的方法Win32ShutDown,Win32ShutDown(flag)中flag的参数可以是下表中的任意一种: 值 描述
0 注销
0 + 4 强制注销
1 关机
1 + 4 强制关机
2 重起
2 + 4 强制重起
8 关闭电源
8 + 4 强制关闭电源
使用ADODB.Stream对象写二进制文件
Function SaveBinaryData(FileName, ByteArray)
Const adTypeBinary = 1
Const adSaveCreateOverWrite = 2
Create Stream object
Dim BinaryStream
Set BinaryStream = CreateObject("ADODB.Stream")
Specify stream type - we want To save binary data.
BinaryStream.Type = adTypeBinary
Open the stream And write binary data To the object
BinaryStream.Open
BinaryStream.Write ByteArray
Save binary data To disk
BinaryStream.SaveToFile FileName, adSaveCreateOverWrite
End Function
使用ADODB.Stream对象写文本文件
Function SaveTextData(FileName, Text, CharSet)
Const adTypeText = 2
Dim BinaryStream
Specify stream type - we want To save text/string data.
BinaryStream.Type = adTypeText
Specify charset For the source text (unicode) data.
If Len(CharSet) > 0 Then
BinaryStream.CharSet = CharSet
End If
BinaryStream.Open
BinaryStream.WriteText Text
End Function
使用ADODB.Stream对象读二进制文件
Function ReadBinaryFile(FileName)
Dim BinaryStream
Specify stream type - we want To get binary data.
Open the stream
BinaryStream.Open
Load the file data from disk To stream object
BinaryStream.LoadFromFile FileName
Open the stream And get binary data from the object
ReadBinaryFile = BinaryStream.Read
End Function
使用ADODB.Stream对象读文本文件
Function ReadTextFile(FileName, CharSet)
Dim BinaryStream
End If
Open the stream
BinaryStream.Open
ReadTextFile = BinaryStream.ReadText
End Function
使用FileSystemObject对象写文件
Function SaveBinaryDataTextStream(FileName, ByteArray)
Create FileSystemObject object
Dim FS: Set FS = CreateObject("Scripting.FileSystemObject")
Create text stream object
Dim TextStream
Set TextStream = FS.CreateTextFile(FileName)
Convert binary data To text And write them To the file
TextStream.Write BinaryToString(ByteArray)
End Function
读取和写入Windows的INI文件
Sub WriteINIStringVirtual(Section, KeyName, Value, FileName)
WriteINIString Section, KeyName, Value, _
Server.MapPath(FileName)
End Sub
Function GetINIStringVirtual(Section, KeyName, Default, FileName)
GetINIStringVirtual = GetINIString(Section, KeyName, Default, _
Server.MapPath(FileName))
End Function
Work with INI files In VBS (ASP/WSH)
v1.00
2003 Antonin Foller, PSTRUH Software, http://www.pstruh.cz
Function GetINIString(Section, KeyName, Default, FileName)
Sub WriteINIString(Section, KeyName, Value, FileName)
Dim INIContents, PosSection, PosEndSection
Get contents of the INI file As a string
INIContents = GetFile(FileName)
Find section
PosSection = InStr(1, INIContents, "[" & Section & "]", vbTextCompare)
If PosSection>0 Then
Section exists. Find end of section
PosEndSection = InStr(PosSection, INIContents, vbCrLf & "[")
?Is this last section?
If PosEndSection = 0 Then PosEndSection = Len(INIContents)+1
Separate section contents
Dim OldsContents, NewsContents, Line
Dim sKeyName, Found
OldsContents = Mid(INIContents, PosSection, PosEndSection - PosSection)
OldsContents = split(OldsContents, vbCrLf)
Temp variable To find a Key
sKeyName = LCase(KeyName & "=")
Enumerate section lines
For Each Line In OldsContents
If LCase(Left(Line, Len(sKeyName))) = sKeyName Then
Line = KeyName & "=" & Value
Found = True
End If
NewsContents = NewsContents & Line & vbCrLf
Next
If isempty(Found) Then
key Not found - add it at the end of section
NewsContents = NewsContents & KeyName & "=" & Value
Else
remove last vbCrLf - the vbCrLf is at PosEndSection
NewsContents = Left(NewsContents, Len(NewsContents) - 2)
End If
Combine pre-section, new section And post-section data.
INIContents = Left(INIContents, PosSection-1) & _
NewsContents & Mid(INIContents, PosEndSection)
elseif PosSection>0 Then
Section Not found. Add section data at the end of file contents.
If Right(INIContents, 2) <> vbCrLf And Len(INIContents)>0 Then
INIContents = INIContents & vbCrLf
End If
INIContents = INIContents & "[" & Section & "]" & vbCrLf & _
end ifif PosSection>0 Then
WriteFile FileName, INIContents
End Sub
Dim INIContents, PosSection, PosEndSection, sContents, Value, Found
Find section
If InStr(1, sContents, vbCrLf & KeyName & "=", vbTextCompare)>0 Then
Found = True
Separate value of a key.
Value = SeparateField(sContents, vbCrLf & KeyName & "=", vbCrLf)
End If
End If
If isempty(Found) Then Value = Default
GetINIString = Value
End Function
Separates one field between sStart And sEnd
Function SeparateField(ByVal sFrom, ByVal sStart, ByVal sEnd)
Dim PosB: PosB = InStr(1, sFrom, sStart, 1)
If PosB > 0 Then
PosB = PosB + Len(sStart)
Dim PosE: PosE = InStr(PosB, sFrom, sEnd, 1)
If PosE = 0 Then PosE = InStr(PosB, sFrom, vbCrLf, 1)
If PosE = 0 Then PosE = Len(sFrom) + 1
SeparateField = Mid(sFrom, PosB, PosE - PosB)
End If
End Function
File functions
Function GetFile(ByVal FileName)
Go To windows folder If full path Not specified.
If InStr(FileName, ":\") = 0 And Left (FileName,2)<>"\\" Then
FileName = FS.GetSpecialFolder(0) & "\" & FileName
End If
On Error Resume Next
GetFile = FS.OpenTextFile(FileName).ReadAll
End Function
Function WriteFile(ByVal FileName, ByVal Contents)
End If
Dim OutStream: Set OutStream = FS.OpenTextFile(FileName, 2, True)
OutStream.Write Contents
End Function
可能会看起来比较乱,大家可以到
http://zeus.hacker.com.cn/codes/classical_VBS.html |
