查看: 746|回复: 3
[求助]:每次启动出现这; 错误: LOAD 失败: "acadapp"
发表于 2003-11-19 11:18:01 | 显示全部楼层 |阅读模式
请问怎样解决呢?卸载了,重新安装都不行
已领礼包: 3656个
发表于 2003-11-19 11:30:13 | 显示全部楼层
我也经常有这种情况的,有时是
; error: LOAD failed: "chg_str"
我找了下面的文件,好像没有加载这个命令的啊
CAD的功能运行正常,望指教
CAD2002
发表于 2003-11-19 11:31:01 | 显示全部楼层
Solution
This error occurs when AutoCAD cannot find the acadapp.arx file due to a corrupt Windows registry or portion of the hard disk where this file resides. The acadapp.arx file contains a variety of functions required by AutoCAD, as well as ObjectARX and ADS applications.
To troubleshoot the cause of this error message:
From the Tools menu, choose Options.
In the Options dialog box, select the Open and Save tab. Make sure that Object Detect and Command Invoke is selected from the Demand Load ARX Apps drop-down menu.
Check that the support paths in the Options dialog box contain the folder where acadapp.arx is located
Copy the acadapp.arx file from the AutoCAD Installation CD to the hard drive to overwrite the existing acadapp.arx file.
Check for another acadapp.arx file on the hard drive by using the Find Files or Folders tool in Windows Explorer. If another acadapp.arx file is found, make sure that AutoCAD cannot find this file in its search path.
If the error recurs, it is possible that a corrupt registry key in the Windows registry is the cause. If this is the case, you need to uninstall and reinstall AutoCAD.
Before you uninstall AutoCAD, save any menu files, AutoLISP?/SUP> files, and any other customized files to a temporary directory. Before you reinstall AutoCAD, reboot the computer and completely remove any directories that remain after uninstalling AutoCAD.
Important: When you reinstall AutoCAD, make sure you reinstall the application to a new directory. If a corrupt registry is the cause of the error, then installing AutoCAD into a new directory will resolve the problem.
嘿嘿,这是帮助文件里的,你看看是不是里面提到的问题。
 楼主| 发表于 2003-11-19 11:40:47 | 显示全部楼层
我重新安装了为何还是不能找到文件??奇怪!
GMT+8, 2026-11-3 15:13 , Processed in 0.440312 second(s), 38 queries , Gzip On.
