查看: 1168|回复: 3
[求助]:标注怎么老跑啊
发表于 2003-11-25 15:41:56 | 显示全部楼层 |阅读模式
我在移动图的时候,有些标注会莫名其妙的跑出去,明明是选中了一起移动的,但它就是移不过去,别的都过去了,就它还站着不动,还有我标注是500的,一移动就成了1000了,而且一边的标注线边的很长很长啊,不知道这是为什么啊,请指教
发表于 2003-11-25 16:05:55 | 显示全部楼层
移动会出现这样的问题吗???我只是接触过缩放(SC)后标注会变形的。。还真想接触一下。。楼主可以把你的那张图搞上来试试吗???
发表于 2003-11-25 18:42:38 | 显示全部楼层
工具-选项里面 设置标注为关联标注
已领礼包: 3655个
发表于 2003-11-25 19:16:03 | 显示全部楼层
命令dimassoc,设置标注对象的关联性,0-分解,1-非关联,2-关联
帮助里是这么说的(E文版)
Type: Integer
Saved in: Drawing
Initial value: 2
Controls the associativity of dimension objects.
0  Creates exploded dimensions. There is no association between the various elements of the dimension. The lines, arcs, arrowheads, and text of a dimension are drawn as separate objects.
1  Creates non-associative dimension objects. The elements of the dimension are formed into a single object. If the definition point on the object moves, the dimension value is updated.
2  Creates associative dimension objects. The elements of the dimension are formed into a single object, and one or more definition points of the dimension are coupled with association points on geometric objects. If the association point on the geometric object moves, the dimension location, orientation, and value is updated.
DIMASSOC is not stored in a dimension style.
GMT+8, 2026-11-3 07:18 , Processed in 0.437748 second(s), 38 queries , Gzip On.
