查看: 1165|回复: 4
[LISP函数]:几个Scripting.FileSystemObject应用函数
发表于 2003-12-5 14:57:08 | 显示全部楼层 |阅读模式
  1.   [FONT=courier new]
  2. 1.  查找指定目录特定文件列表
  3.    ;;;(FindFiles_lst "c:\\hqd9639" "*`.dwg")
  4.   (defun findfiles_lst (dir Pattern / FILSYS pattern folderobj Files result)
  5.     (vl-load-com)
  6.     (setq FILSYS (vlax-create-object "Scripting.FileSystemObject"))
  7.     (if (/= (vlax-invoke-method FILSYS "FolderExists" dir) :vlax-false)
  8.         (progn
  9.            (setq pattern (strcase pattern))
  10.            (setq folderobj (vlax-invoke-method FILSYS "GetFolder" dir))
  11.            (setq Files (vlax-get-property folderobj "Files"))
  12.            (vlax-for file files
  13.                  (if (wcmatch (strcase (vla-get-name file)) pattern)
  14.                      (setq result (cons (vla-get-path file) result))
  15.                  )
  16.                  (vlax-release-object file)
  17.            )
  18.            (vlax-release-object files)
  19.            (vlax-release-object folderobj)
  20.            (vlax-release-object FILSYS)
  21.            result
  22.         )
  23.         (progn
  24.            (vlax-release-object FILSYS)
  25.            nil
  26.         )
  27.     )
  28.   )
  29.   ;;;
  30. 2. 用VLISP重命名文件夹
  31.   ;;;(ren_folder "c:\\hqd9639" "hqd")
  32.   (defun ren_folder (oldfolder newname / FILSYS folderobj)
  33.     (vl-load-com)
  34.     (setq FILSYS (vlax-create-object "Scripting.FileSystemObject"))
  35.     (if (/= (vlax-invoke-method FILSYS "FolderExists" oldfolder) :vlax-false)
  36.         (progn
  37.             (setq folderobj (vlax-invoke-method FILSYS "GetFolder" oldfolder))
  38.             (if (/= (vla-get-Name folderobj) newname)
  39.                 (progn
  40.                    (vla-put-Name folderobj newname)
  41.                    T
  42.                 )
  43.                 nil
  44.             )
  45.         )
  46.         nil
  47.     )
  48.   )
  49. ;;;
  50. 3.   用VLISP获取硬盘系列号
  51.   ;;;(GET_DRIVE_SN "c")
  52.   (defun get_drive_sn (drive / FILSYS driveobj)
  53.     (vl-load-com)
  54.     (setq FILSYS (vlax-create-object "Scripting.FileSystemObject"))
  55.     (if (/= (vlax-invoke-method FILSYS "DriveExists" drive) :vlax-false)
  56.         (progn
  57.            (setq driveobj (vlax-invoke-method FILSYS "GetDrive" drive))
  58.            (vlax-get-property driveobj "SerialNumber")
  59.         )
  60.         nil
  61.     )
  62.   )
  63.   [/FONT]
已领礼包: 488个
发表于 2003-12-6 17:09:05 | 显示全部楼层
发表于 2003-12-6 20:25:24 | 显示全部楼层
斑竹为什么我把程序拿回去调试的时候总是提示 “错误: 参数太少”呢
用VLISP获取硬盘系列号这个东西很有用可以用来作加密程序。
我以前只知道可以取到mac地址可是mac可以改
难道还有人能够吧用硬盘系列号也改掉吗
已领礼包: 4个
发表于 2003-12-7 12:15:10 | 显示全部楼层
获取序列号的好像以前龙龙仔写过。结果和doslib的两样的是数字的
发表于 2003-12-9 19:28:51 | 显示全部楼层
这个东东我还没有调试好,请大家帮帮忙好吗
GMT+8, 2026-11-4 07:21 , Processed in 0.471694 second(s), 40 queries , Gzip On.
