查看: 921|回复: 3
[求助]:"migration tools"一套 那里可以下载啊?
发表于 2003-12-18 08:55:50 | 显示全部楼层 |阅读模式
前几天买电脑,公司里面都安装了2000的版本,好爽,重装系统后就没了,求助
最好是2004版本
发表于 2003-12-18 09:26:32 | 显示全部楼层
全都可以在www.autodesk.com/migrationtools找到,不过Autodesk Customization Conversion Tools只有英文版的,另外一个Autodesk Batch Drawing Converter 2004,论坛上也有。
发表于 2003-12-18 10:26:25 | 显示全部楼层
migration tools
是什么软件?
 楼主| 发表于 2003-12-18 10:36:38 | 显示全部楼层
AutoLISP Compatibility Analyzer details AutoCAD 2004 compatibility issues found in AutoLISP® and Menu LISP files. When an issue is found, an explanation of the compatibility issue and suggestions on how to correct it are provided.
Menu and Toolbar Porter is designed to help you import your menus and toolbar items from previous versions of AutoCAD into AutoCAD 2004. You can also use this tool to add or remove menu and toolbar items from any AutoCAD MNU file.
Command Alias (PGP) Porter is designed to help you import your custom command aliases from previous versions of AutoCAD into AutoCAD 2004. You can also use this tool to add, replace, or remove command aliases from any AutoCAD PGP file.
ScriptPro takes AutoCAD scripting to a new level with an easy-to-use interface, logging, reusable project files, enhanced scripting with new keywords and utilities, and robust error recovery. Using ScriptPro you can apply a set of commands to multiple drawings by simply specifying a script file and the list of drawings that you would like to apply the script to.
Layer State Converter allows you to convert between the layer states created by LMAN (one of the AutoCAD® Express Tools) and the saved layer states introduced in AutoCAD 2000i software.
To use Layer State Converter, type one of the following commands on the AutoCAD command line:
'CONVERTLS' converts AutoCAD layer states to LMAN layer states.
'CONVERTLMAN' converts LMAN layer states to AutoCAD layer states.
里面有这些工具
GMT+8, 2026-11-3 21:02 , Processed in 0.482714 second(s), 37 queries , Gzip On.
