查看: 1022|回复: 3
[求助]:无法启动win98
发表于 2003-12-26 19:48:46 | 显示全部楼层 |阅读模式
CPU赛扬733,今天上午用windows优化大师全面优化后15分钟显示OUT OF RANGE 死机重起,过了一会依旧如此。
随后想重新复覆盖安装win98,检查scandisk显示C盘有错误,fixed
重起后再进入,无法安装98,有如下显示:
standard mode :Fault in MS-DOS Extender
EC=03E4 CS=0053 IP=2821 AX=ABC0 BX=0000 CX=FFFF DX=FFFF SI=0277 DI=0186 BP=4278 DS=004B ES=02EC SS=004B SP=426E
Standard mode: Bad Fault in MSDOS Extender
Fault: 0007 stack Dump : 030C 0000 0070
Raw Fault Frame : EC=03E4 IP=245B CS=0053 FL=3097 SP=00F2 SS=004B
无法继续安装,退出。
因为C盘桌面有汉语的文件夹,有用文件。DOS下
copy c:\windows\desktop\*.* e:\1234
则仅考贝了桌面的文件,无法copy 文件夹的内容。
求助: 1。 如何解决?
   2。 DOS下如何copy 汉语子目录下的文件
3。C盘格式化后安装能否进行? *-*5
发表于 2003-12-26 20:26:16 | 显示全部楼层
你到华军去下一个启动盘试试,软件为全中文MS-dos7.1(win98),就可以实现汉字目录的操作拉
发表于 2003-12-26 20:32:35 | 显示全部楼层
1&2) 用XCOPY命令,加/S参数。这是一个外部命令,程序文件在C:\WINDOWS\COMMAND下面。Win98的XCOPY命令用法:
Copies files and directory trees.
XCOPY source [destination] [/A | /M] [/D[:date]] [/P] [/S [/E]] [/W]
                           [/C] [/I] [/Q] [/F] [/L] [/H] [/R] [/T] [/U]
                           [/K] [/N]
source       Specifies the file(s) to copy.
destination  Specifies the location and/or name of new files.
/A           Copies files with the archive attribute set,
              doesn't change the attribute.
/M           Copies files with the archive attribute set,
              turns off the archive attribute.
/D:date      Copies files changed on or after the specified date.
              If no date is given, copies only those files whose
              source time is newer than the destination time.
/P           Prompts you before creating each destination file.
/S           Copies directories and subdirectories except empty ones.
/E           Copies directories and subdirectories, including empty ones.
              Same as /S /E. May be used to modify /T.
/W           Prompts you to press a key before copying.
/C           Continues copying even if errors occur.
/I           If destination does not exist and copying more than one file,
              assumes that destination must be a directory.
/Q           Does not display file names while copying.
/F           Displays full source and destination file names while copying.
/L           Displays files that would be copied.
/H           Copies hidden and system files also.
/R           Overwrites read-only files.
/T           Creates directory structure, but does not copy files. Does not
              include empty directories or subdirectories. /T /E includes
              empty directories and subdirectories.
/U           Updates the files that already exist in destination.
/K           Copies attributes. Normal Xcopy will reset read-only attributes.
/Y           Overwrites existing files without prompting.
/-Y          Prompts you before overwriting existing files.
/N           Copy using the generated short names.
Win2K的XCOPY命令的用法(中文版):
复制文件和目录树。
XCOPY source [destination] [/A | /M] [/D[:date]] [/P] [/S [/E]] [/V] [/W]
                           [/K] [/N] [/O] [/X] [/Y] [/-Y] [/Z]
                           [/EXCLUDE:file1[+file2][+file3]...]
  source       指定要复制的文件。
  destination  指定新文件的位置和/或名称。
  /A           只复制有存档属性集的文件,
               但不改变属性。
  /M           只复制有存档属性集的文件,
               并关闭存档属性。
  /D:m-d-y     复制在指定日期或指定日期以后改变的文件。
               如果没有提供日期,只复制那些源时间
               比目标时间新的文件。
               指定含有字符串的文件列表。如果有任何
               字符串与要被复制的文件的绝对路径
               相符,那个文件将不会得到复制。
               例如,指定如 \obj\ 或 .obj 的字符串会排除
               目录 obj 下面的所有文件或带有
               .obj 扩展名的文件。
  /P           创建每个目标文件前提示。
  /S           复制目录和子目录,除了空的。
  /E           复制目录和子目录,包括空的。
               与 /S /E 相同。可以用来修改 /T。
  /V           验证每个新文件。
  /W           提示您在复制前按键。
  /C           即使有错误,也继续复制。
  /I           如果目标不存在,又在复制一个以上的文件,
               则假定目标一定是一个目录。
  /Q           复制时不显示文件名。
  /F           复制时显示完整的源和目标文件名。
  /L           显示要复制的文件。
  /H           也复制隐藏和系统文件。
  /R           改写只读文件。
  /T           创建目录结构,但不复制文件。不
               包括空目录或子目录。/T /E 包括
               空目录和子目录。
  /U           只复制已经存在于目标中的文件。
  /K           复制属性。一般的 Xcopy 会重设只读属性。
  /N           用生成的短名复制。
  /O           复制文件所有权和 ACL 信息。
  /X           复制文件审核设置(隐含 /O)。
  /Y           禁止提示以确认改写一个
               现存目标文件。
  /-Y          导致提示以确认改写一个
               现存目标文件。
  /Z           用重新启动模式复制网络文件。
命令选项 /Y 可以预先在 COPYCMD 环境变量中设置。
这可能被命令行上的 /-Y 改写。
3) 不知道。
 楼主| 发表于 2003-12-27 02:35:24 | 显示全部楼层
谢谢斑主的帮助,我去拷贝有用文件,再格式化试试。
文件我按斑主的方法已经xcopy 到F盘,谢谢。但系统无法启动,格式化后也无法安装win98。两次98系统重装重起后黑屏。多次无法开始安装。总提示bad Fault in MS-DOS.
周六安装一天都失败了。
周日休息。
周一开机即开始安装。一次性成功,但不清楚是什么原因。
谢谢大家的帮助!
节日快乐!
周二中午机器又死了!!*-*a
GMT+8, 2026-11-6 06:09 , Processed in 0.268920 second(s), 38 queries , Gzip On.
