查看: 1885|回复: 2
[密技]:IAcadDictionaries.Item的真相
发表于 2002-9-3 15:49:00 | 显示全部楼层 |阅读模式
困惑许久,今日豁然
不敢独珍,与诸君分享
From maxd
Can anyone tell me how I can list the names of all the dictionaries attached to
the ActiveDocument. I am using VB6 and AutoCad 2000. The code line below gives
me a type mismatch.
  1. Set objDictionary = objAcad.ActiveDocument.Dictionaries.Item(i)
复制代码
Hey there maxd -
The Dictionaries object doesn't contain just Dictionary objects as the help
file, or even this code,
  1. Public Sub TheLIE()
  2.   Dim objLibrary As AcadDictionaries
  3.   Dim intCnt As Integer
  4.   Set objLibrary = ThisDrawing.Dictionaries
  5.   For intCnt = 0 To objLibrary.Count - 1
  6.     Debug.Print objLibrary(intCnt).ObjectName
  7.   Next intCnt
  8. End
  9. 'Results from a new drawing:
  10. 'AcDbDictionary
  11. 'AcDbDictionary
  12. 'AcDbDictionary
  13. 'AcDbDictionary
  14. 'AcDbDictionaryWithDefault
suggests!
Here is the truth:
  1. Public Sub TheTruth()
  6.     Debug.Print TypeName(objLibrary(intCnt))
  7.   Next intCnt
  8. End
  9. 'Results in same drawing:
  10. 'IAcadGroups
  11. 'IAcadLayouts
  12. 'IAcadDictionary
  13. 'IAcadPlotConfigurations
  14. 'IAcadDictionary
AHA! Now, an example of how to work with what's really in there:
  1. Public Sub CheckOut()
  3.   Dim objDictionary As AcadDictionary
  4.   Dim objLayOuts As AcadLayouts
  5.   Dim objGroups As AcadGroups
  6.   Dim objPlots As AcadPlotConfigurations
  7.   Dim objEach As Object
  8.   Dim intCnt As Integer
  9.   Set objLibrary = ThisDrawing.Dictionaries
  10.   For intCnt = 0 To objLibrary.Count - 1
  11.     Select Case TypeName(objLibrary(intCnt))
  12.       Case "IAcadGroups"
  13.         Set objGroups = objLibrary(intCnt)
  14.           For Each objEach In objGroups
  15.             Debug.Print objEach.Name
  16.           Next objEach
  17.       Case "IAcadLayouts"
  18.         Set objLayOuts = objLibrary(intCnt)
  19.           For Each objEach In objLayOuts
  20.             Debug.Print objEach.Name
  21.           Next objEach
  22.       Case "IAcadDictionary"
  23.         Set objDictionary = objLibrary(intCnt)
  24.         Debug.Print objDictionary.Name
  25.       Case "IAcadPlotConfigurations"
  26.         Set objPlots = objLibrary(intCnt)
  27.           For Each objEach In objPlots
  28.             Debug.Print objEach.Name
  29.           Next objEach
  30.       Case Else
  31.         Debug.Print "VODKA MARTINI"
  32.     End Select
  33.   Next intCnt
  34. End
发表于 2020-9-17 22:07:07 | 显示全部楼层
this is what i need!
发表于 2020-9-23 00:50:26 | 显示全部楼层
thanks you.
GMT+8, 2026-11-22 09:03 , Processed in 0.402890 second(s), 14 queries , Gzip On, File On.
