查看: 872|回复: 2
[讨论]:能否用vlisp取出硬盘的序列号
发表于 2004-1-7 15:50:02 | 显示全部楼层 |阅读模式
能否用vlisp取出硬盘的序列号
已领礼包: 593个
发表于 2004-1-8 01:18:12 | 显示全部楼层
Re: [讨论]:能否用vlisp取出硬盘的序列号
最初由 playboy 发布
[B]能否用vlisp取出硬盘的序列号 [/B]
置顶帖子中有链接
  1. [php]
  2. ;|
  3. 函数名: VxGetDriveInfos
  4. 功  能: 返回选择磁盘信息
  5. Copyright:   ?001 MENZI ENGINEERING GmbH, Switzerland
  6. 参数[类型]:
  7.    Drv = 盘符, 如. "C" 或 "C:" [字串]
  8. 返回值[类型]:
  9.   磁盘信息 '(TotalSize FreeSpace DriveType FileSystem SerialNumber ShareName VolumeName) [表]
  10. 说明:
  11.   - TotalSize (kB) [实数] 磁盘空间或 network share.
  12.   - FreeSpace (kB) [REAL] 空闲空间 or network share.
  13.   - DriveType [INT]
  14.      0 = "Unknown"
  15.      1 = "Removable"
  16.      2 = "Fixed"
  17.      3 = "Network"
  18.      4 = "CD-ROM"
  19.      5 = "RAM Disk"
  20.   - FileSystem [STR]  磁盘系统格式, 如. "FAT", "NTFS", "CDFS".
  21.   - SerialNumber [INT] Returns the serial number used to uniquely identify a disk volume.
  22.   - ShareName [STR]  Returns the network share name (UNC) for the specified drive. If it's
  23.                      not a network drive, ShareName returns a zero-length string ("").
  24.   - VolumeName [STR] 卷标
  25.      0 The drive doesn't exist.
  26.      1 The drive is not ready. For removable-media drives and CD-ROM drives,
  27.      VxGetDriveInfos returns -1 when the appropriate media is not inserted
  28.      or not ready for access.
  29. 注意: 需要 ScrRun.dll.
  30. |;
  31. (defun VxGetDriveInfos (Drv / DrvObj FilSys RetVal)
  32.   (setq        FilSys (vlax-create-object "Scripting.FileSystemObject")
  33.         RetVal (cond
  34.                  ((= (vlax-invoke FilSys "DriveExists" Drv) 0) 0)
  35.                  ((setq DrvObj (vlax-invoke FilSys "GetDrive" Drv))
  36.                   (cond
  37.                     ((= (vlax-get DrvObj "IsReady") 0) -1)
  38.                     ((list
  39.                        (/ (vlax-get DrvObj "TotalSize") 1000.0)
  40.                        (/ (vlax-get DrvObj "FreeSpace") 1000.0)
  41.                        (vlax-get DrvObj "DriveType")
  42.                        (vlax-get DrvObj "FileSystem")
  43.                        (vlax-get DrvObj "SerialNumber")
  44.                        (vlax-get DrvObj "ShareName")
  45.                        (vlax-get DrvObj "VolumeName")
  46.                      )
  47.                     )
  48.                   )
  49.                  )
  50.                )
  51.   )
  52.   (if DrvObj
  53.     (vlax-release-object DrvObj)
  54.   )
  55.   (vlax-release-object FilSys)
  56.   RetVal
  57. )[/php]
 楼主| 发表于 2004-1-8 13:00:53 | 显示全部楼层
谢谢斑竹的帮助
mac地址如何取呀
GMT+8, 2026-11-4 06:24 , Processed in 0.595334 second(s), 36 queries , Gzip On.
