查看: 1498|回复: 8
[求助] [求助]:关于vla-put-Alignment
发表于 2004-1-7 17:08:15 | 显示全部楼层 |阅读模式
用VLA把一个文字添加到一个块定义中后,再用vla-put-Alignment修改文字齐属性。
问题:插入这个块后,发现vla-put-Alignment的修改并没有起做用,当把块炸开后,才会起作用。用了updtae也不行。请问怎样解决这个问题?
发表于 2004-1-7 17:33:41 | 显示全部楼层
最好把你的程序贴出来让大家看看再说。
 楼主| 发表于 2004-1-8 10:57:03 | 显示全部楼层
问题主要存在于对非激活文档的操上,可如下测:
同时新建两个文档 Drawing1、 Drawing2,
激活 Drawing1,执行
(setq docobj (vla-get-ActiveDocument (vlax-get-acad-object)))
(vl-propagate 'docobj);将变量复制到全部文档。
以临时获得一个文档对象,用于测试。
激活 Drawing2,执行
(setq mspace (vla-get-modelspace docobj))
(setq blk (vla-add (vla-get-Blocks docobj) (vlax-3d-point '(0 0 0)) "blk"))
(vla-addline blk (vlax-3d-point '(10 10 0)) (vlax-3d-point '(66 10 0)))
(vla-addline blk (vlax-3d-point '(66 10 0)) (vlax-3d-point '(66 20 0)))
(vla-addline blk (vlax-3d-point '(66 20 0)) (vlax-3d-point '(10 20 0)))
(vla-addline blk (vlax-3d-point '(10 20 0)) (vlax-3d-point '(10 10 0)))
(setq textobj (vla-addtext blk "HHHHHHHH" (vlax-3d-point '(10 10 0)) 10))
(vla-put-Alignment textobj acAlignmentMiddleCenter)
(vla-put-TextAlignmentPoint textobj (vlax-3d-point '(10 10 0)))
(vla-InsertBlock mspace (vlax-3d-point '(0 0 0)) "blk"  1 1 1 0)
激活 Drawing1,炸开刚插入的块,就会发现文字的对齐方式改变。
如果是单档操作则不会有题。
发表于 2004-1-9 07:59:50 | 显示全部楼层
  1. ;;把text的性質再看一遍吧!
  2. (defun C:TT ()
  3.   (setq MSPACE (vla-get-modelspace DOCOBJ))
  4.   (setq        BLK (vla-add (vla-get-blocks DOCOBJ)
  5.                      (vlax-3d-point '(0 0 0))
  6.                      "blk"
  7.             )
  8.   )
  9.   (vla-addline
  10.     BLK
  11.     (vlax-3d-point '(10 10 0))
  12.     (vlax-3d-point '(66 10 0))
  13.   )
  14.   (vla-addline
  15.     BLK
  16.     (vlax-3d-point '(66 10 0))
  17.     (vlax-3d-point '(66 20 0))
  18.   )
  19.   (vla-addline
  20.     BLK
  21.     (vlax-3d-point '(66 20 0))
  22.     (vlax-3d-point '(10 20 0))
  23.   )
  24.   (vla-addline
  25.     BLK
  26.     (vlax-3d-point '(10 20 0))
  27.     (vlax-3d-point '(10 10 0))
  28.   )
  29.   (setq
  30.     TEXTOBJ (vla-addtext BLK "HHHHHHHH" (vlax-3d-point '(10 10 0)) 10)
  31.   )
  32.   (vla-put-alignment TEXTOBJ acalignmentmiddlecenter)
  33.   (vla-put-textalignmentpoint
  34.     TEXTOBJ
  35.     (vlax-3d-point '(50 15 0))
  36.   )
  37.   (vla-insertblock
  38.     MSPACE
  39.     (vlax-3d-point '(0 0 0))
  40.     "blk"
  41.     1
  42.     1
  43.     1
  44.     0
  45.   )
  46. )
  47. ;;激活 Drawing1,炸開剛插入的塊,就會發現文字的對齊方式改變。
指定屬性、屬性參考、或文字的水平與垂直對齊。
信號
object.Alignment
object                Attribute、AttributeRef、Text這個性質適用的物件。
Alignment        acAlignment 列舉;讀/寫
                acAlignmentLeft
                acAlignmentCenter
                acAlignmentRight
                acAlignmentAligned
                acAlignmentMiddle
                acAlignmentFit
                acAlignmentTopLeft
                acAlignmentTopCenter
                acAlignmentTopRight
                acAlignmentMiddleLeft
                acAlignmentMiddleRight
                acAlignmentBottomLeft
                acAlignmentBottomCenter
                acAlignmentBottomRight
說明
對齊到 acAlignmentLeft 的文字使用 InsertionPoint 性質來放置文字。
對齊到 acAlignmentAligned 或 acAlignmentFit的文字同時使用 InsertPoint 以及 TextAlignmentPoint 性質來放置文字。
對齊到其它任何位置的文字使用 TextAlignmentPoint 性質來方置文。
指定文字與屬性的對齊點。
信號
object.TextAlignmentPoint
TextAlignmentPoint        變體(倍精度的三元素陣列);讀/寫3D WCS 座標值,代表物件的對齊點。
說明
Text: 當 Alignment 性質設成 acAlignmentLeft 時,這個性質會重設成  0, 0, 0 而且變成唯讀。;
要放置對正方式為靠左、佈滿、或對齊的文字,請使用 InsertPoint 性質。
 楼主| 发表于 2004-1-9 09:18:29 | 显示全部楼层
楼上说的已理解。
问题存在于同是上面一段程序,如果操作的文档对象DOCOBJ是当前激活的文档不会有问题,如果不是当前的激活文档,就不行了。
顺便也说一下DELETE,也是这样,如果操作的文档对象DOCOBJ是当前激活的文档不会有问题,如果不是当前的激活文档,就不行了。
发表于 2004-1-9 09:45:34 | 显示全部楼层
最初由 dxqyz 发布
[B]楼上说的已理解。
顺便也说一下DELETE,也是这样,如果操作的文档对象DOCOBJ是当前激活... [/B]
再說清楚OR有代碼嗎?
 楼主| 发表于 2004-1-9 13:43:37 | 显示全部楼层
代码:
(defun blk ( / )
  (blk)
  (setq docobj (vla-add (vla-get-Documents (vlax-get-acad-object))))
  (blk)  ;;;新问题:此次调用BLK函数会出错,但如果把函数代码直接复制到这就不会有问题了。
执行上面代码后,对比当前文档和新建的文档会发现,
同样的代码在两个文档中的执行结果是不相同的。
已领礼包: 488个
发表于 2004-1-10 00:29:40 | 显示全部楼层
(defun blk ( / )
(setq blk ;;;这里blk给你重新定义了,第二遍执行当然不行了.
开一个新文档重新执行,肯定行!
至于不同,那可能是字型的关系.
 楼主| 发表于 2004-1-13 12:36:41 | 显示全部楼层
最初由 aeo 发布
[B]
至于不同,那可能是字型的关系. [/B]
不会是字型吧,只是用了几个字母,同样的系统。
GMT+8, 2026-11-4 06:24 , Processed in 0.624843 second(s), 48 queries , Gzip On.
