查看: 1081|回复: 2
[求助]:jig问题!救命!
发表于 2004-1-7 21:27:18 | 显示全部楼层 |阅读模式
arx如何对AcDbBlockReference进行拖动啊?
高手救命!
发表于 2004-1-8 10:57:08 | 显示全部楼层
类似拖动一个固定半径的园,只要在jig派生中,对插入点作处理即可
 楼主| 发表于 2004-1-8 15:11:13 | 显示全部楼层
我的可以实现移动拖动,但是移动拖动后旋转拖动就不对了,发现是以移动拖动后确定的点为基点,原先块的位置为起始位置,进行旋转。而不是块在我拖动确定的点处为基点进行旋转的
AcEdJig::DragStatus
AsdkMyJig::sampler()
    DragStatus stat;
    //setSpecialCursorType(kRotatedCrosshair);
    setUserInputControls((UserInputControls)
        (AcEdJig::kAccept3dCoordinates
         | AcEdJig::kNoNegativeResponseAccepted
         | AcEdJig::kNoZeroResponseAccepted));
    if (mPromptCounter == 0) {
      static AcGePoint3d axisPointTemp(0.0,0.0,0.0);
        stat = acquirePoint(mAxisPt, AcGePoint3d(0.0,0.0,0.0));
        if (axisPointTemp != mAxisPt)
            axisPointTemp = mAxisPt;
                        //AcGeMatrix3d xform;
                        mInsertPt=mAxisPt;
                        AcGeVector3d Vector(mAxisPt[X],mAxisPt[Y],mAxisPt[Z]);//-axisPointTemp;
                        xform.setToTranslation(Vector);
        else if (stat == AcEdJig::kNormal)
            return AcEdJig::kNoChange;
    else if (mPromptCounter == 1) {
        static double angTemp=-1;
                //AcGePoint3d basePnt=mInsertPt;
        stat = acquireAngle(mAng, mInsertPt);
        if (angTemp != mAng)
            //mAng = ang;
                        xform.setToRotation(mAng,mNormal,mInsertPt);
    return stat;
// This function is called to update the entity based on the
// input values.
Adesk::Boolean
AsdkMyJig::update()
    switch (mPromptCounter) {
    case 0:
//                {AcGeVector3d Vector(mInsertPt[X],mInsertPt[Y],mInsertPt[Z]);//-axisPointTemp;
//                xform.setTranslation(Vector);}
        break;
    case 1:
                {//acutPrintf("\ninsertPt=%f       %f    %f",mInsertPt[X],mInsertPt[Y],mInsertPt[Z]);
                //mNormal=AcGeVector3d(0,0,1);
                //xform.setToRotation(mAng,mNormal,mInsertPt);
                //.setToProduct(xform,form);
        break;
GMT+8, 2026-11-22 09:38 , Processed in 0.375915 second(s), 12 queries , Gzip On, File On.
