查看: 1042|回复: 5
[求助]:如何将选中的实体保存到另一个文件?
发表于 2004-1-8 17:47:14 | 显示全部楼层 |阅读模式
如何将选中的实体保存到另一个文件?
要求原有的实体属性不变。
已领礼包: 181个
发表于 2004-1-8 19:51:19 | 显示全部楼层
1、创建一个对象数组,保存选中实体。如:Dim objCollection(0 To 1) As Object
2、打开那个文件,如:doc。
3、使用ThisDrawing.CopyObjects objCollection,doc,将实体拷贝到刚打开的文件中。
 楼主| 发表于 2004-1-9 10:22:00 | 显示全部楼层
CopyObjects 的参数如何设置,我老是设不对
doc1  对象所在文件
doc2 目标文件
objCollection 对象集
doc1.CopyObjects (objCollection, doc2)
但我这样设后,还是出错,“CopyObjects 不能应用在IAcadDocument 上"
发表于 2004-1-16 09:18:28 | 显示全部楼层
用Wblock
  1. Sub Example_WBlock()
  2.     ' This example creates several objects in model space and
  3.     ' adds them to a selection set. This selection set is then
  4.     ' output as a new drawing file.
  5.
  6.     ' Create a Ray object in model space
  7.     Dim rayObj As AcadRay
  8.     Dim basePoint(0 To 2) As Double
  9.     Dim SecondPoint(0 To 2) As Double
  10.     basePoint(0) = 3#: basePoint(1) = 3#: basePoint(2) = 0#
  11.     SecondPoint(0) = 1#: SecondPoint(1) = 3#: SecondPoint(2) = 0#
  12.     Set rayObj = ThisDrawing.ModelSpace.AddRay(basePoint, SecondPoint)
  13.
  14.     ' Create a polyline object in model space
  15.     Dim plineObj As AcadLWPolyline
  16.     Dim points(0 To 5) As Double
  17.     points(0) = 3: points(1) = 7
  18.     points(2) = 9: points(3) = 2
  19.     points(4) = 3: points(5) = 5
  20.     Set plineObj = ThisDrawing.ModelSpace.AddLightWeightPolyline(points)
  21.     plineObj.Closed = True
  22.     ' Create a line object in model space
  23.     Dim lineObj As AcadLine
  24.     Dim startPoint(0 To 2) As Double
  25.     Dim endPoint(0 To 2) As Double
  26.     startPoint(0) = 0: startPoint(1) = 0: startPoint(2) = 0
  27.     endPoint(0) = 2: endPoint(1) = 2: endPoint(2) = 0
  28.     Set lineObj = ThisDrawing.ModelSpace.AddLine(startPoint, endPoint)
  29.
  30.     ' Create a circle object in model space
  31.     Dim circObj As AcadCircle
  32.     Dim centerPt(0 To 2) As Double
  33.     Dim radius As Double
  34.     centerPt(0) = 20: centerPt(1) = 30: centerPt(2) = 0
  35.     radius = 3
  36.     Set circObj = ThisDrawing.ModelSpace.AddCircle(centerPt, radius)
  37.     ' Create an ellipse object in model space
  38.     Dim ellObj As AcadEllipse
  39.     Dim majAxis(0 To 2) As Double
  40.     Dim center(0 To 2) As Double
  41.     Dim radRatio As Double
  42.     center(0) = 5#: center(1) = 5#: center(2) = 0#
  43.     majAxis(0) = 10: majAxis(1) = 20#: majAxis(2) = 0#
  44.     radRatio = 0.3
  45.     Set ellObj = ThisDrawing.ModelSpace.AddEllipse(center, majAxis, radRatio)
  46.     ZoomAll
  47.
  48.     ' Create a selection set
  49.     Dim ssetObj As AcadSelectionSet
  50.     Set ssetObj = ThisDrawing.SelectionSets.Add("WBLOCKSET")
  51.
  52.     ' Iterate through the model space collection and add
  53.     ' each item found to an array of objects
  54.     ReDim objsInModelSpace(0 To ThisDrawing.ModelSpace.count - 1) As AcadEntity
  55.     Dim I As Integer
  56.     For I = 0 To ThisDrawing.ModelSpace.count - 1
  57.         Set objsInModelSpace(I) = ThisDrawing.ModelSpace.Item(I)
  58.     Next
  59.
  60.     ' Add the array of objects into the selection set
  61.     ssetObj.AddItems objsInModelSpace
  62.
  63.     ' Output the selection set to a new file
  64.     ThisDrawing.Wblock "C:\AutoCAD\WBlock_example.dwg", ssetObj
  65.
  66. End Sub
已领礼包: 488个
发表于 2004-2-1 16:19:00 | 显示全部楼层
最初由 gephen 发布
[B]CopyObjects 的参数如何设置,我老是设不对
doc1  对象所在文件
doc2 目标文件
objCollection 对象集
但我这样设后,还是出错,“CopyObjects 不能应用在IAcadDocumen... [/B]
我想是应该要进入modelspace,或者其他的对象中吧!
doc1.modelspace.CopyObjects (objCollection, doc2.modelspace)
"对象所在文件"还不是对象集的"上级"
发表于 2004-2-3 23:29:24 | 显示全部楼层
如果要求实体拷贝到另一文件中后变化比例,要求图形变大或变小时,用VBA如何实现?
GMT+8, 2026-11-3 11:16 , Processed in 0.441839 second(s), 42 queries , Gzip On.
