查看: 1877|回复: 11
[编程申请]:谁编过将大量的小段线连接成 pline 的程序
已领礼包: 1915个
财富等级: 堆金积玉
发表于 2004-1-8 19:00:25 | 显示全部楼层 |阅读模式
我们常常从勘测部门购买的地形图,其中的地形线是由无数的小短线构成,使用不方便,而且文件巨大,谁编过将大量的小段线连接成 pline 的程序。小短线都是首尾相接的。
发表于 2004-1-8 19:08:45 | 显示全部楼层
http://www.xdcad.net/forum/showthread.php?threadid=122886
对有相同节点的pl线的程序
发表于 2004-1-8 19:46:00 | 显示全部楼层
ET里有plinejoin命令可以解决
发表于 2004-1-8 20:26:14 | 显示全部楼层
不是大量的小段线,而是夹点很密的样条曲线,都是由于做地形图时没进行清理过滤造成的。必须在原作图软件下重新进行清理过滤。
已领礼包: 2个
发表于 2004-1-21 10:13:15 | 显示全部楼层
1.(defun c:pp ()
  (command "pedit" pause "y" "j" "all" "" "")
  (princ)
2.(defun C:vvv (/ s1 n1 n e1 e2 z k a)
  (vl-load-com)
  (princ
    "\n½«ËùѡʵÌåÁ¬³É¶àÒåÏߣ¬²¢ÅÐ¶ÏÆäÊÇ·ñ±ÕºÏ. °æÈ¨ËùÓУºTH.ÑÔÎ÷Ôç¶þ"
  (setq z (getvar "cmdecho"))
  (setvar "cmdecho" 0)
  (command "undo" "be")
  (setq s1 (ssget))
  (setq n1 (sslength s1))
  (setq n 0)
  (while (< n n1)
    (setq e1 (ssname s1 n))
    (setq e2 (entget e1))
    (if        (/= nil e2)
      (progn
        (setq a (cdr (assoc 0 e2)))
        (if (= a "LINE")
          (progn (command "pedit" e1 "y" "j" "all" "" "")
                 (setq k (entlast))
                 (if (/= (vlax-curve-isClosed k) t)
                   (command "change" k "" "p" "c" 7 "")
                   (command "change" k "" "p" "c" 30 "")
          (if (= a "arc")
                   (setq k (entlast))
    (setq n (1+ n))
  (setvar "cmdecho" z)
  (command "undo" "e")
  (prin1)
3.(defun c:vv (/ z d c b k)
  (vl-load-com)
  (princ
    "\n&frac12;&laquo;&Euml;ù&Ntilde;&iexcl;&sup2;&atilde;&Eacute;&Iuml;&micro;&Auml;&Ecirc;&micro;&Igrave;&aring;&Aacute;&not;&sup3;&Eacute;&para;à&Ograve;&aring;&Iuml;&szlig;&pound;&not;&sup2;&cent;&Aring;&ETH;&para;&Iuml;&AElig;&auml;&Ecirc;&Ccedil;·&ntilde;±&Otilde;&ordm;&Iuml;. °&aelig;&Egrave;¨&Euml;ù&Oacute;&ETH;&pound;&ordm;TH.&Ntilde;&Ocirc;&Icirc;÷&Ocirc;&ccedil;&para;&thorn;"
  (setq c (getstring "\n &Ecirc;&auml;&Egrave;&euml;&sup2;&atilde;&Atilde;&ucirc;:"))
  (while (setq a (ssget "x" (list (cons lc c) (cons 0 "line"))))
    (setq b (ssname a 0))
    (command "change" B "" "p" "c" 30 "")
    (command "pedit" b "y" "j" "all" "" "")
    (setq k (entlast))
      (command "change" k "" "p" "c" 232 "")
  (while (setq a (ssget "x" (list (cons 8 c) (cons 0 "arc"))))
    (setq k (entlast))
  (princ)
已领礼包: 593个
发表于 2004-1-21 13:15:57 | 显示全部楼层
Re: [编程申请]:谁编过将大量的小段线连接成 pline 的程序
最初由 zhang8755 发布
[B]我们常常从勘测部门购买的地形图,其中的地形线是由无数的小短线构成,使用不方便,而且文件巨大,谁编过将大量的小段线连接成 pline 的程序。小短线都是首尾相接的。 [/B]
早有讨论,如果用2002或者2004,标准的Pedit命令就可以办到。
已领礼包: 1915个
财富等级: 堆金积玉
 楼主| 发表于 2004-1-21 23:58:57 | 显示全部楼层
能否实现无需选择,只敲一个命令就将图中的首尾相连的短线连接为pline,或某一层上的短线连接成pline.
已领礼包: 2个
发表于 2004-1-27 13:41:56 | 显示全部楼层
用我写的程序就可以呀!VVV是"将所选实体连成多义线,并判断其是否闭合",而VV是"将所选层上的实体连成多义线,并判断其是否闭合"
发表于 2004-1-30 20:46:55 | 显示全部楼层
作到任选一线:连最长的PLine;再依次以前一交点为终点连最长的PLine
发表于 2004-1-30 22:47:04 | 显示全部楼层
[code] (defun c:jbyl ( / ss d)
  (while (setq e (entsel "\n选层上参照实体:"))
    (setq ss (ssget "x" (list (assoc 8 (entget (car e)))))
          ss (ssget "p" '((0 . "POLYLINE,LWPOLYLINE,ARC,LINE")))
          d  (if d d (getdist "\n断线容差:")))
    (cond
      (ss
       (if (setq ss2 (ssget "p" '((0 . "ARC,LINE"))))
         (repeat (setq n (sslength ss))
           (vl-cmdf ".pedit" (ssname ss (setq n (1- n))) "y" "")
           (ssadd (entlast) ss)
       (vl-cmdf ".pedit" "m" ss "" "y" "j" d "")
  )(princ)
发表于 2018-11-16 15:35:25 | 显示全部楼层
哟没有   大神!!
已领礼包: 130个
发表于 2018-11-24 10:07:12 | 显示全部楼层
晓东工具箱这个工具本身就有呀  你装上就有的
GMT+8, 2026-11-5 03:49 , Processed in 0.416106 second(s), 54 queries , Gzip On.
