楼主: 党员
[日积月累]:上个世纪美国的一些标准图
 楼主| 发表于 2004-1-13 10:25:04 | 显示全部楼层
61/65
 楼主| 发表于 2004-1-13 10:25:36 | 显示全部楼层
62/65
 楼主| 发表于 2004-1-13 10:26:09 | 显示全部楼层
63/65
 楼主| 发表于 2004-1-13 10:26:57 | 显示全部楼层
64/65
 楼主| 发表于 2004-1-13 10:27:35 | 显示全部楼层
65/65
发表于 2004-4-5 16:33:17 | 显示全部楼层
太多了,都是些什么?
有没有阅览图?
发表于 2004-4-14 13:36:02 | 显示全部楼层
怎么没有贴图啊
下过的人说说话啊
发表于 2004-4-16 22:53:38 | 显示全部楼层
02141        1        Typical Dry Well Surface Drainage
02271        1        Typical Wire Mesh Gabion Assembly
02315        1 - A        Typical Road Data - General
        1 - B        Typical Road Data
02334        1        Typical Water Retention Pit
        2        Typical Minor Retention Dam
02513        1        Asphaltic Concrete Curb
02525        1        Typical Well Construction Details
        2        Typ. Well Const. Details-Concrete Platform
        3        Typ. Well Const. Details-Earth Platform
        4        Typical Hand Lift Pump Base
        5        Typ. Submersible Pump Installation Type A
        6        Typ. Submersible Pump Installation Type B
        7        Typical Stuffing Box Pump-Type A
        8        Typical Stuffing Box Pump-Type B
02528        1        Concrete Curbs
        1- A        Precast Concrete Parking Stop
02607        1        Concentric Manhole
        2        Eccentric Manhole
        2 - A        Precast Eccentric Manhole
        3        Concentric Drop Manhole
        4        Eccentric Drop Manhole
02608        1        Sewer Cleanout
02646        1        Fire Hydrant
02665        1        Pipeline Installation Types
        2        Typical Curb Valve
        3        Typ. Air and Vacuum Release Valve
        4        Concrete Thrust Blocks (for Pipelines)
02719        1        Drainage Inlet - Type I
02719        2 - A        Drainage Inlet - Type II
        2 - B        Drainage Inlet - Type II
        3        Drainage Inlet - Type III
02722        1        Culvert Data - Bedding Details
        2        Culvert Data - Skew Numbe
        3        Standard Round Pipe Culvert End Sections
        4        Std. Pipe - Arch Culvert End Sections
        5        Std. Culvert - Installation Notes
        6 - A        Coupling Bands for Corrugated Metal Pipe
        6 - B        Coupling Bands for Corrugated Metal Pipe
        6 - C        Coupling Bands for Corrugated Metal Pipe
        7        Std. Reinf. Concrete Pipe Bedding Details
        8        Broken Back Culvert Installation
        9        Standard Culvert Tables
        10 - A        Safety Slope End Sect.for Circ.& Arch.Pipes(A)
        10 - B        Safety Slope End Sect.for Circ.& Arch.Pipes(B)
        11 - A        Safety Slope End Sect.for Rd.& Elliptical Conc.Pipes(A)
        11 - B        Safety Slope End Sect.for Rd.& Elliptical Conc.Pipes(B)
02729        1        Trail Clearing and Grubbing
        2        Trail Cross-Sections
        3        Trail Stream Fords
        4        Trail Tread Drainage Dip
        5        Trail Tread Drainage Log or Rock Waterbar
        6        Trail Switchback Section
        7        ORV Trail Clearing
        8        ORV Climbing Turn
02745        1        Concrete Septic Tank
        1 - A        Cast-In-Place Septic Tank
        2        Steel Septic Tank
02779        1        Waterbar Detail
02802        1        Steel Water Trough
        2        Round Water Trough Installation
        3        Birdwalk
        4        Big Game Water Tank Field Installation
02803        1        Loading Ramp
02823        1        Snow Fence Type I
        2        Snow Fence Type II
02824        1        Typical Barbed Wire Fence (4-Wire)
        2        Typical Barbed Wire Fence (3-Wire)
        3        High-Tensile Wire Fences
        4        Typical Woven Wire Fence
        5        Figure Four and Rock Jack
        6        Typical Wire Gates
        7        Typical Steel Gates
        8 - A        Steel Pipe Gate
        8 - B        Lockbox & Locking Pins-Steel Pipe Gate
        9        Corner Panels (wood)
        10        Typical Post, Pole and Wire Fence
        11        Typical Mechanical Gate Closer
        12        Lay-Down Fence
        13        Corner Panel (steel pipe)
        14        End Panel (steel pipe)
02829        1        Electric Fence Details
        2        Electric Fence Gates
        3        Energizer Assembly
02831        1        Typical Chain Link Fence
        2        Typical Chain Link Gates
02835        1        Pole Fence
        2        Buck and Pole Fence
        3        Wood Gates
        4        Swinging Pole Gate
02836        1        Fence-Drainage Crossing-Type A
        2        Fence-Drainage Crossing-Type B
        3        Fence-Drainage Crossing-Type C
        4        Fence-Drainage Crossing-Type D
02838        1        Typical Sheep Exclosure
        2        Typical Livestock & Rodent Exclosure
        3        Typical Cattle Exclosure
        4        Big Game Exclosure
        5        Study Layout, Livestock-Big Game Excl.
02843        1 - A        Guardrail - W Beam
        1 - B        Guardrail - W Beam
        1 - C        Guardrail - W Beam
02844        1        Concrete Guard Posts
        2        Wood Guard Posts
        3        Cable Gate (Concrete Post)
        4        Cable Gate (Wood Post)
        5        Rock Barriers
        6        Timber Barriers
02874        1        Picnic Table-Wood (Non-Accessible)
        2        Picnic Table-Wood & Conc. (Non Accs.)
        3        Picnic Table-Wood & Pipe (Non Accs.)
02875        1        Refuse Container Rack
        2        Typical Garbage Can Holders
        3        Bearproof Garbage Can
02877        1        Flip-Top Camp Grills
        2        Grill Base Detail
        3        Fire Circles and Hole
02880        1        Antelope Pass Structure Through Fence
02881        1        Steel Cattle Guard Grid (w/o Cleanout)
        2        Steel Pipe Cattle Guard Grid
        3        Railroad Rail Cattle Guard
        4        Cattle Guard Wings
        5        Cattle Guard Foundation (Timbers)
        6        Cattle Guard Found. (Cast-in-Place Conc.)
        7        Cattle Guard Found. (Precast Concrete)
02891        1        Project Sign
        2        Delineators
        3        Administrative Site Sign Rock Base
        4        Trail Sign
02892        1        Paved Waterways
02895        1        Typical Project Monument
13209        1        Welded Steel Tank
        2        Skid-Mounted Water Storage Tank
13215        1        Underground Storage Tank (Steel)
13216        1        Underground Storage Tank (FRP)
13701        1        Typical Windmill Installation
National Science & Technology Center
P.O. Box 25047
Bldg. 50, Denver Federal Center
Denver, Colorado 80225-0047
(303) 236-2772
FAX (303) 236-6450
GMT+8, 2026-11-3 03:58 , Processed in 0.557007 second(s), 40 queries , Gzip On.
