查看: 1347|回复: 9
[求助]:用vb 编程如何设置线宽。
发表于 2004-1-28 11:31:27 | 显示全部楼层 |阅读模式
用vb 编程如何设置线宽。谢谢
发表于 2004-2-1 11:59:20 | 显示全部楼层
编程申请里我有一个,你去找找!
已领礼包: 3532个
发表于 2004-2-2 22:41:07 | 显示全部楼层
楼上!给个联接!
我找了半天,没有找到!
你自己的知道位置,方便一下!
发表于 2004-2-3 12:17:10 | 显示全部楼层
楼上的,我自己也不知道连接啊,呵呵,如果我知道我肯定帖上去了!
已领礼包: 181个
发表于 2004-2-4 11:58:10 | 显示全部楼层
设置线宽要分成两种情况,一是实体的类型不是多段线的要先转换成多段线。二是使用SetWidth来设置多段线的线宽。
发表于 2004-2-29 13:50:39 | 显示全部楼层
Sub jcx() '加粗直线程序
Dim a
On Error Resume Next
Dim i As Integer
Dim allobj As AcadEntity
Dim spnt As Variant
Dim epnt As Variant
Dim plineobj As AcadLWPolyline
Dim ver(0 To 3) As Double
For i = 0 To ThisDrawing.SelectionSets.Count - 1
ThisDrawing.SelectionSets.Item(i).Clear
ThisDrawing.SelectionSets.Item(i).Delete
Next
Dim sset As AcadSelectionSet
Set sset = ThisDrawing.SelectionSets.Add("lineset")
sset.SelectOnScreen
If sset.Count = 0 Then Exit Sub
Dim w As String
w = ThisDrawing.Utility.GetString(1, vbCrLf & "请输入宽度:")
For Each allobj In sset
If allobj.ObjectName <> "AcDbLine" Then
allobj.ConstantWidth = w
End If
If allobj.ObjectName = "AcDbLine" Then
spnt = allobj.StartPoint
epnt = allobj.EndPoint
ver(0) = spnt(0): ver(1) = spnt(1)
ver(2) = epnt(0): ver(3) = epnt(1)
Set plineobj = ThisDrawing.ModelSpace.AddLightWeightPolyline(ver)
plineobj.ConstantWidth = w
allobj.Delete
End If
'删除直线
Next
Exit Sub
End Sub
发表于 2004-3-1 12:44:28 | 显示全部楼层
能否为小弟介绍一下VB与AUTOCAD的接口技术
我写了下面的程序可就是CAD 程序不出来
Dim acadapp As AcadApplication
Set acadapp = GetObject(, "Autocad.Application")
If Err Then
Err.Clear
Set acadapp = New AcadApplication
  If Err Then
  MsgBox Err.Description
  Exit Sub
  End If
End If
MsgBox "Now running" + acadapp.Name + "version" + acadapp.Version
ThisDrawing.Application.Documents.Add
Dim inspoint(0 To 2) As Double
Dim textheight As Double
Dim textstr As String
Dim textobj As AcadText
inspoint(0) = Val(TextBox1)
inspoint(1) = Val(TextBox2)
inspoint(2) = Val(TextBox3)
textheight = Val(TextBox4)
textstr = TextBox5
Set textobj = ThisDrawing.ModelSpace.AddText(textstr, inspoint, textheight)
ThisDrawing.SaveAs ("hello.dwg")
发表于 2004-3-1 18:57:23 | 显示全部楼层
出来了,只是没有显示出来!
加上下面这行代码
acadapp.Visible=True
发表于 2004-3-10 16:18:03 | 显示全部楼层
需要明确一下,许多文章都介绍采用GetObject(, "Autocad.Application")与CAD建立联系,其实这还差一点点,造成联接不稳定,CAD2002应为GetObject(, "Autocad.Application.15") ,CAD2004应为GetObject(, "Autocad.Application.16") ,这以前很少提及。
发表于 2004-3-10 18:32:18 | 显示全部楼层
楼上说的很对,不加版本号是一种通用调用,在写程序给不知道对方装的是什么版本的autocad时最为适用,当然如果知道版本加上则更为准确!~
GMT+8, 2026-11-3 15:17 , Processed in 0.563884 second(s), 50 queries , Gzip On.
