查看: 939|回复: 1
[ARX程序]:请问:怎样返回一个选择集呢?
发表于 2002-9-18 13:41:10 | 显示全部楼层 |阅读模式
怎样使函数返回一个选择集呢?
已领礼包: 145个
发表于 2002-9-18 13:45:15 | 显示全部楼层
首先,要用ADSRX结构,用ads_defun 定义外部函数,才能返回数据给LISP。
返回的方法:
  ads_retname(ss,RTPICKS);
因为选择集和实体都使用了ads_name 类型,所以,加了RTPICKS 告诉ARX返回的是选择集
如果返回实体:
  ads_retname(ent,RTENAME);
  1. [FONT=courier new]
  2. int
  3. acedRetName(
  4.     const ads_name aname,
  5.     int type);
  6. Include File
  7. acedads.h
  8. Returns a selection set or entity name, aname, to AutoLISP. The type argument must equal RTPICKS if aname specifies a selection set, or RTENAME if aname specifies an entity. The AutoLISP expression that invoked the external function returns the name result as built-in and user-defined AutoLISP functions do.
  9. An external function can make more than one call to value-return functions upon a single kInvkSubrMsg message, but the AutoLISP function returns only the value passed it by the last value-return function invoked.
  10. If acedRetName() succeeds, it returns RTNORM; it returns RTERROR if it fails or if aname is a null pointer.[/FONT]
GMT+8, 2026-11-3 01:42 , Processed in 0.526246 second(s), 34 queries , Gzip On.
