查看: 1106|回复: 2
[ARX程序]:xd, 问一下:怎样判断一个Arx是否已加载?
发表于 2002-9-20 17:13:00 | 显示全部楼层 |阅读模式
谢谢!
lyhSoft
已领礼包: 145个
发表于 2002-9-20 19:06:23 | 显示全部楼层
使用:
Global Functions
AcRx Global Functions
  acrxLoadedApps
Include File
rxregsvc.h
void*
acrxLoadedApps();
This function returns a pointer to an AcDbVoidPtrArray that contains copies of the file names or URLs of all the currently loaded ObjectARX applications. These are the same strings that are reported by the AutoCAD ObjectARX command's "?" option.
It is the caller's responsibility to free all the strings in the array and to delete the array itself when finished with it.
获得当前加载的ARX应用程序。
下面给你个代码:
  1. [FONT=courier new]
  2. bool isModuleLoaded(const char* str)
  3. {
  4.         AcDbVoidPtrArray* pApps = reinterpret_cast<AcDbVoidPtrArray*>(acrxLoadedApps());
  5.         if (pApps==NULL)
  6.                 return false;
  7.         bool bFound = false;
  8.         for (int i=0;i<pApps->length();i++)
  9.         {
  10.                 if (stricmp(reinterpret_cast<const char*>(pApps->at(i)),str)==0)
  11.                 {
  12.                         bFound = true;
  13.                         break;
  14.                 }
  15.         }
  16.         for (;pApps->length()>0;)
  17.         {
  18.                 delete reinterpret_cast<char*>(pApps->at(0));
  19.                 pApps->removeAt(0);
  20.         }
  21.         delete pApps;
  22.         return bFound;
  23. }
  24. [/FONT]
复制代码
 楼主| 发表于 2002-9-22 09:20:53 | 显示全部楼层
我找了半天,都想不出  appload . Arx  的原理 !  谢谢你,xd!
GMT+8, 2026-11-2 22:09 , Processed in 0.402309 second(s), 36 queries , Gzip On.
