查看: 833|回复: 1
[教学]:ADN文章,转换Polygon Mesh 到 polylines
已领礼包: 145个
发表于 2004-2-15 01:27:59 | 显示全部楼层 |阅读模式
LISP: How do I convert a Polygon Mesh into polylines?
ID    76913
Applies to:    AutoCAD 2004
AutoCAD 2002
Date    9/16/2003
This document is part of   Visual Lisp   Polyline   Complex Entities
Question
Using Visual LISP, is there a way to reduce Polygon Meshs (3D Meshs) into regular
polylines or lines?
Answer
While Visual LISP has no built-in method for converting a polygon mesh to polylines
(or lines), you can explode it, and then draw polylines using the coordinates
of the resulting 3dFaces.  The sample code below demonstrates this.  It searches
modelspace for polygon mesh objects, explodes them into 3dFaces, draws polylines
(adding vertices to the the 3dFace coordinates), and deletes the original mesh
(and faces):
[PHP]
(defun c:XplPgMesh (/ oApp oDoc oMSp oObj vXplObj aXplObj oObjLst oObj2 vCoords o3dPline)
   (VL-LOAD-COM)
   (setq oApp (vlax-get-acad-object)
           oDoc (vla-get-activedocument oApp)
           oMSp (vla-get-modelspace oDoc)
   ) ;setq
   (vlax-for oObj oMsp
      (if (= (vla-get-objectname oObj) "AcDbPolygonMesh")
         (if (setq vXplObj (vla-explode oObj))
            (progn
               (setq aXplObj (vlax-variant-value vXplObj))
               (if (not (minusp (vlax-safearray-get-u-bound aXplObj 1))) ;check for empty safearray
                  (progn
                     (setq oObjLst (vlax-safearray->list aXplObj))
                     (foreach oObj2 oObjLst
                        (if (= (vla-get-objectname oObj2) "AcDbFace")
                           (progn
                              (setq vCoords (vla-get-coordinates oObj2)
                                      o3dPline (vla-Add3DPoly oMSp vCoords)
                              ) ;setq
                              (vlax-put-property o3dPline 'Closed :vlax-true)
                              (vla-delete oObj2)
                              (vlax-release-object o3dPline)
                           ) ;progn
                        ) ;if
                     ) ;foreach
                     (foreach itm oObjLst (vlax-release-object itm))
                  ) ;progn
               ) ;if
               (vla-delete oObj)
            ) ;progn
         ) ;if
      ) ;if
   ) ;vlax-for
   (princ)
[/PHP]
已领礼包: 593个
发表于 2004-2-15 08:49:43 | 显示全部楼层
Date 9/16/2003
希望看到越来越多的解冻资料,有用没用的当做学习了。
GMT+8, 2026-11-4 08:13 , Processed in 0.533984 second(s), 34 queries , Gzip On.
