查看: 1149|回复: 4
[推荐]:有关Autocad2005的一些问题,希望对大家有帮助!
发表于 2004-2-19 23:05:39 | 显示全部楼层 |阅读模式
When will AutoCAD 2005 and AutoCAD 2005 products be available?
Shipments will commence in April. Until then special offers are available on certain AutoCAD 2004 based products which will include an automatic upgrade to the AutoCAD 2005 based product.
Can I try AutoCAD 2005 before I buy it?
Yes. You can try it by requesting the a trial version. Contact Excitech for details.
Can I run AutoCAD 2005 side-by-side on my computer with AutoCAD® 2004,2002, 2000i, or 2000?
Yes, AutoCAD 2005 is designed to run side-by-side with the AutoCAD
2000/2000i/2002/2004 versions, enabling you to make a smooth transition to the new
release of AutoCAD. AutoCAD 2005’s migration feature helps you make a smooth
transition to the new release by automatically migrating customized menus, hatch patterns,
linetypes, command short cuts and AutoCAD profiles.
Has the AutoCAD 2005 drawing file format (DWG) changed from the AutoCAD
2004 file format, as it did between AutoCAD 2002 and AutoCAD 2004?
No, the new features and functionality developed in AutoCAD 2005 maintain DWG and
DXF™ file compatibility between the AutoCAD 2004 and AutoCAD 2005 software versions.
You can directly and easily share files between different design teams using AutoCAD 2004
and AutoCAD 2005. In addition, AutoCAD 2005 has a built-in SaveAs function to save
drawings in AutoCAD 2000/2000i/2002 format.
Does AutoCAD 2005 read and save drawings created by earlier releases of
AutoCAD?
Yes, AutoCAD 2005 reads drawing files from all previous versions of AutoCAD software.
AutoCAD 2005 has a built-in SaveAs function so you can save and safely round-trip
drawings to and from AutoCAD releases 2000/2000i/2002 and 2004 DWG formats. In
addition, you can use the SaveAs AutoCAD Release 12 DXF command to support releases
prior to AutoCAD 2000.
Also, the Autodesk® Batch Drawing Converter 2005 can be used to convert any AutoCAD or
AutoCAD-based drawing file to AutoCAD Release 14, AutoCAD 2000, AutoCAD 2000i,
AutoCAD 2002, and AutoCAD 2004 file formats. The Autodesk Batch Drawing Converter
2005 is a free download available from Autodesk.
Is AutoCAD 2005 compatible with AutoCAD LT 2005?
Yes, AutoCAD 2005 software is fully DWG-compatible with AutoCAD LT® 2005 software. It
can read files from all older versions of AutoCAD LT and can save to the AutoCAD LT 2004
and 2002/2000i/2000 DWG file formats for compatibility with older products.
Do AutoCAD 2000/2000i/2002/2004 customized files work in AutoCAD 2005?
Yes, with some modifications. AutoCAD 2005 includes a migration feature that will
automatically migrate customized AutoCAD 2000/2000i/2002/2004 menus, hatch patterns,
linetypes, command short cuts and AutoCAD profiles. This feature can migrate your
customizations at install time or after you have installed AutoCAD 2005. For more
information on migrating your customized files, please consult the AutoCAD online Help.
How are AutoLISP programs affected by changes in AutoCAD 2005?
AutoLISP® routines, linetype files, hatch patterns, PGP files and other customizations that
have been written for AutoCAD 2000/2000i/2002/2004 releases should work in AutoCAD
2005; no changes have been made that would affect them.
Will my third-party application that runs on AutoCAD 2004 be available for
AutoCAD 2005?
Yes, AutoCAD 2005 is both DWG and application compatible with AutoCAD 2004.
Applications from third parties—whether they are based on ObjectARX®, COM Automation,
VBA/VB, or Visual LISP®—that support either product do not require an update. Autodesk
has been providing prerelease software and technical guidance to members of the Autodesk
Developer Network to ensure that their applications will work for you. You should contact
your application developer/supplier if you have any questions regarding your application.
Do AutoCAD 2000/2000i/2002 third-party applications work with AutoCAD
2005?
Maybe. Some AutoCAD 2000/2000i/2002 third-party add-on applications based on Visual
LISP and VBA may be compatible with AutoCAD 2005. Third -party applications based on
ActiveX and ObjectARX will require upgrades to be compatible with AutoCAD 2005. There
are numerous compatible applications available for AutoCAD 2005. Check with your
application developer/supplier regarding availability of applications built for AutoCAD 2005.
Will the AutoCAD 2000i/2002/2004 extensions work with AutoCAD 2005?
All the modular functionality delivered in the AutoCAD 2000i/2002/2004 extensions has
been built into AutoCAD 2005. Therefore, the AutoCAD 2000i/2002/2004 extensions will not
install on AutoCAD 2005 and are not necessary.
Is AutoCAD 2005 interoperable with other Autodesk products?
AutoCAD 2005 is the foundation for an interoperable family of Autodesk products. Sharing
the same database framework component—ObjectDBX™ for reading and writing drawing
files—ensures that the next generation of Autodesk products is interoperable with AutoCAD
2005. These products include 3ds max® and Autodesk® VIZ 4, Autodesk® DWF™ Viewer,
Autodesk® Raster Design, Autodesk® OnSite View, and the AutoCAD industry-specific
desktop products, including Autodesk Map™, AutoCAD® Mechanical, Autodesk® Mechanical
Desktop®, Autodesk® Architectural Desktop, Autodesk® Land Desktop, and Autodesk® Civil
Design.
Can I run AutoCAD 2005 side-by-side with other AutoCAD platform –based
applications?
Yes, AutoCAD 2005 can be installed side-by-side with any other AutoCAD or AutoCAD–
based product versions—including AutoCAD 2005–based versions. These products include
Autodesk Mechanical Desktop, AutoCAD Mechanical, Autodesk Architectural Desktop,
Autodesk Land Desktop, Autodesk Civil Design, Autodesk Map, and AutoCAD LT software.
What are the system requirements for AutoCAD 2005?
The system requirements for AutoCAD 2005 are as follows:
· Intel® Pentium® III or later, with 800 MHz or faster processor, or compatible
· Microsoft® Windows® XP (Professional, Home Edition, or Tablet PC Edition),
or Windows® 2000 Professional
· 256 MB RAM
· 300 MB free disk space for installation
· 1024x768 VGA with true color
· Microsoft® Internet Explorer 6.0
· CD-ROM drive
· Mouse, trackball, or compatible pointing device
Is AutoCAD 2005 certified for Microsoft® Windows® XP?
Yes, AutoCAD has received “Designed for Windows XP—Optimized for Enterprise” logo
certification. This is the highest level of logo certification that Microsoft offers. The logo
certification program ensures that software runs smoothly and reliably in the Windows
operating system environment. Several fundamental changes have been made to AutoCAD
to ensure its robust performance when running on the latest version of the Windows
operating system. These changes include the ability to run AutoCAD as a limited rights user,
making it easy for multiple AutoCAD-based products to be run on the same computer, and
changes to the file structures and use of the registry that support roaming user profiles.
Does AutoCAD 2005 support Tablet PCs running Windows XP?
Yes, AutoCAD 2005 software supports Microsoft Windows XP for Tablet PC operating system
functionality, including the ability to specify landscape or portrait orientation as well as
right- or left-handedness, enabling you to take full advantage of the portability that the
Tablet PC offers.
Which new plotters are supported by AutoCAD 2005?
AutoCAD 2005 includes updated HDI drivers for the OCÉ® and Xerox® devices and updated
Hewlett Packard® Windows system drivers that support Microsoft Windows® XP
Professional/Home and Windows 2000. For more details on AutoCAD 2005 plotter support,
please consult your plotter manufacturer.
发表于 2004-2-20 09:28:19 | 显示全部楼层
没看懂
发表于 2004-2-20 09:38:18 | 显示全部楼层
大哥怎么全是E文啊
我 看不懂啊?
发表于 2004-2-22 22:54:15 | 显示全部楼层
现在讨论2005有点早了。
发表于 2004-2-22 23:18:20 | 显示全部楼层
看了一下介绍,不错。
GMT+8, 2026-11-5 02:13 , Processed in 0.492133 second(s), 40 queries , Gzip On.
