查看: 1131|回复: 0
[VBA程序]:创建和插入“块”的纯ActiveX/VBA 代码
发表于 2002-9-27 18:16:33 | 显示全部楼层 |阅读模式
How to create/insert a block using pure ActiveX/VBA code
ID    47502
Applies to:    AutoCAD 2000
This document is part of    Block Reference   COM-ActiveX Interfaces   VBA
Question
How should I use the AutoCAD ActiveX Automation API to create a block and insert
it into model space?
Answer
The sequence of the block creation process in ActiveX is to add an AcadBlock
object to the AcadBlocks collection, then you add an AcadCircle, such as to the
AcadBlock. Note that you can add as many objects as you like to the AcadBlock.
When done, call InsertBlock() method to insert it into a particular space, such
as model space.  The following example illustrates this:
  1. [FONT=courier new]
  2. Sub createInsertBlock()
  3.    Dim blk As AcadBlock
  4.    Dim pt(0 To 2) As Double
  5.    Dim cir As AcadCircle
  6.    Dim ctr(0 To 2) As Double
  7.    Const blkName = "test"
  8.
  9.    Set blk = ThisDrawing.Blocks.Add(pt, blkName)
  10.    ctr(0) = 2: ctr(1) = 2
  11.
  12.    Set cir = blk.AddCircle(ctr, 1.5)
  13.
  14.    ThisDrawing.ModelSpace.InsertBlock pt, blkName, 1, 1, 1, 0
  15. End Sub[/FONT]
GMT+8, 2026-11-22 09:44 , Processed in 0.311341 second(s), 10 queries , Gzip On, File On.
