查看: 992|回复: 2
[VBA函数]:请教晓东
发表于 2002-10-9 16:55:23 | 显示全部楼层 |阅读模式
请问:晓东为什么我的这个程序对于如下图所示的多义线有的向外偏移,有的向里偏移?
   程序如下:
Public Sub main()
       Call InRdsComp
       Call OutRdsComp
End Sub
Sub InRdsComp()
Dim rds As Double
rds = InputBox("请输入偏移距离", "输入")
Dim Insets As AcadSelectionSet
Dim snum As Integer
Dim existf As Boolean
    For snum = 0 To ThisDrawing.SelectionSets.Count - 1
        If ThisDrawing.SelectionSets.Item(snum).Name = "InEnts" Then
          existf = True
    Exit For
        End If
    Next
    If existf = True Then
        Set Insets = ThisDrawing.SelectionSets.Item("InEnts")
        Insets.Clear
    Else
        Set Insets = ThisDrawing.SelectionSets.Add("InEnts")
    End If
Dim gpCode(0) As Integer
gpCode(0) = 8
Dim dataValue(0) As Variant
dataValue(0) = "InlayerBAid"
Dim groupCode, dataCode As Variant
groupCode = gpCode
dataCode = dataValue
Insets.Select acSelectionSetAll, , , groupCode, dataCode
Dim i, entsnum As Integer
Dim ent As AcadEntity
Dim entry As Variant
entsnum = Insets.Count
For i = 0 To entsnum - 1
    Set ent = Insets.Item(i)
    ent.Highlight (True)
    MsgBox "this is" & ent.ObjectName
    If StrComp(ent.ObjectName, "AcDbCircle", 1) = 0 Or StrComp(ent.ObjectName, "AcDbEllipse", 1) = 0 Then
     entry = ent.Offset(-rds)
     entry(0).Color = acRed
     Else
     entry = ent.Offset(rds)
   End If
Next
End Sub
Sub OutRdsComp()
Dim rds As Double
Dim Outsets As AcadSelectionSet
Dim snum As Integer
        If ThisDrawing.SelectionSets.Item(snum).Name = "OutEnts" Then
          existf = True
    Exit For
        End If
    Next
        Set Outsets = ThisDrawing.SelectionSets.Item("OutEnts")
        Outsets.Clear
    Else
        Set Outsets = ThisDrawing.SelectionSets.Add("OutEnts")
    End If
gpCode(0) = 8
dataValue(0) = "OutlayerBAid"
groupCode = gpCode
Outsets.Select acSelectionSetAll, , , groupCode, dataCode
entsnum = Outsets.Count
    Set ent = Outsets.Item(i)
      entry(0).Color = acBlue
    Else
     End If
Next
End Sub
登录/注册后可看大图
 楼主| 发表于 2002-10-9 16:59:41 | 显示全部楼层
我执行程序后运行的结果如图
发表于 2002-10-9 17:04:33 | 显示全部楼层
最初由 luln 发布
[B]我执行程序后运行的结果如图 [/B]
对于曲线,除LINE外,输入正值,是往曲线增大的趋势偏移。
GMT+8, 2026-11-22 09:44 , Processed in 0.306490 second(s), 15 queries , Gzip On, File On.
