查看: 1137|回复: 2
[求助]:如何对变比例的块中的三维实体进行干涉检查
发表于 2002-10-10 03:23:01 | 显示全部楼层 |阅读模式
已领礼包: 145个
发表于 2002-10-10 03:25:34 | 显示全部楼层
Re: [求助]:如何对变比例的块中的三维实体进行干涉检查
最初由 i_want_2 发布
[B]如何对变比例的块中的三维实体进行干涉检查 [/B]
给你贴篇资料,看看是否有帮助。
  1. [FONT=courier new]
  2. Testing interference of solid in non-uniformly transformed block
  3. ID    2029
  4. Applies to:    AutoCAD 2000I
  5. AutoCAD 2002
  6. This document is part of    Coordinates and Transformations   Solids   Block Reference   Intersecting Entities
  7. Question
  8. How can I test whether two solids interfere, if one is in a BLOCK, which has
  9. a non-uniform transformation.
  10. Answer
  11. ACIS doesn't allow non-uniform transformations on the solids. Since its going
  12. to be ACIS that does the interference detection, this will be a problem,
  13. assuming that you want to interfere one solid which has the transformation
  14. and one which does not. If you are testing two block references which both
  15. have the same transformation, then one can simply test the contents of the
  16. block without applying the transformation.
  17. An alternative approach would be to facet the solids, transform the facets,
  18. and test these. There are various techniques for extracting facets listed
  19. elsewhere, for example using the ACRE functions, or calling the worldDraw
  20. function of the solid. The disadvantage to this approach is that you have to write
  21. the code to check the facet interference, and the result would only be to a
  22. certain tolerance.
  23. Testing whether two facets interfere is fairly straightforward, assuming the
  24. facets are triangular. If the two triangles are coplanar, then just test
  25. whether any of the line segments intersect, and if not, whether either
  26. triangle lies wholly inside the other. If they are not coplanar, then take
  27. each edge of the facet and calculate whether it intersects the plane of the
  28. other triangle. If it does, check whether the intersection point lies within
  29. the triangle.
  30. Finally, if you know that the facetted models do not interfere, you'll need
  31. to check whether one solid is contained entirely within the other. To do
  32. this, take any point on one of the solids, transform this point with the
  33. transform of its block references. Then transform the point with the inverse
  34. of the transformation of the block references of the other solid ( to get it
  35. back into the space of the other solid ). Then test whether it lies inside
  36. the solid ( using the B-Rep API point containment function ). You'll have to
  37. do this both ways round of course.
  38. [/FONT]
 楼主| 发表于 2002-10-10 03:48:56 | 显示全部楼层
thank you
GMT+8, 2026-11-2 21:47 , Processed in 0.467769 second(s), 36 queries , Gzip On.
