查看: 1391|回复: 2
[求助]:如何用VBA获得相对一个测试点在实体的最近点?
发表于 2002-10-13 10:35:07 | 显示全部楼层 |阅读模式
用GETENTITY方法拾取一个实体,得到的实体名和点,但是这个点不一定是实体上的点,如何用VBA获得相对这个点在实体的最近点?
发表于 2002-10-13 11:42:21 | 显示全部楼层
GETENTITY方法返回实体名和鼠标点,这个鼠标点是按照PICKBOX变量设置的,因此点有可能不在实体上,如果要获得实体上的点,用GETPOINT和OSNAP,看下下面的代码:
  1. [FONT=courier new]
  2. Sub test()
  3. Dim obj As Object
  4. Dim ss As AcadSelectionSet
  5. Dim allSS As AcadSelectionSets
  6. Dim pt As Variant
  7. Dim Oldsnapmode As Variant
  8. Dim strName As String
  9. 'Store the current setting of Osnap.
  10. Oldsnapmode = ThisDrawing.GetVariable("OSMODE")
  11. 'Specify the Osnap you want. 512 = Nearest point.
  12. ThisDrawing.SetVariable "OSMODE", 512
  13. pt = ThisDrawing.Utility.GetPoint(, "Pick an entity: ")
  14. Set allSS = ThisDrawing.SelectionSets
  15. 'Check to see if "myset" exists, if so delete it
  16. For Each ss In allSS
  17.    strName = ss.Name
  18.    If ss.Name = "myset" Then
  19.         ss.Delete
  20.         Exit For
  21.    End If
  22. Next
  23. Set ss = ThisDrawing.SelectionSets.Add("myset")
  24. ss.SelectAtPoint (pt)
  25. Set obj = ss.Item(0)
  26. ss.Delete
  27. 'The type of entity selected.
  28. MsgBox "Entity " & obj.EntityName & " was selected at X= " & pt(0) & " and Y= "
  29. & pt(1)
  30. 'Restore Osnap setting.
  31. ThisDrawing.SetVariable "OSMODE", Oldsnapmode
  32. End Sub[/FONT]
发表于 2020-9-5 09:42:36 | 显示全部楼层
学习了,谢谢!
GMT+8, 2026-11-22 08:41 , Processed in 0.208749 second(s), 14 queries , Gzip On, File On.
