查看: 1897|回复: 15
[求助]:怎样把CAD平面图转化成轴侧图?
发表于 2004-3-29 22:09:39 | 显示全部楼层 |阅读模式
怎样把CAD平面图转化成轴侧图?
发表于 2004-3-30 05:51:02 | 显示全部楼层
AutoCAD本身还不具备这个功能.
发表于 2004-4-2 12:05:24 | 显示全部楼层
可以用ACAD画轴侧图的功能
发表于 2004-4-2 14:49:40 | 显示全部楼层
我是用45度角画出来的
发表于 2004-4-2 15:30:24 | 显示全部楼层
没有那个功能的~我平时用30度画~~
发表于 2004-4-2 15:57:09 | 显示全部楼层
这个问题好办。
你直接按着你的图形。
将你的cad设置为等轴测模式。然后去画即可啊。!
发表于 2004-4-3 20:47:25 | 显示全部楼层
是画系统图吗?用这个lsp试试。
注意:把平面图复制好,炸开
(defun c:zc (/         abc bbb acl ace ang a         q   n         qx  qy         ang1         i
             b         c   sx         sy  ex         ey  ps         pe  r         r1  r2         p1  p2         p3
             cl         cc  as         ae  s         a1  a2         a1x a1y a2x a2y
  (setq        abc (getvar "cmdecho")
        bbb (getvar "osmode")
        acl (getvar "clayer")
        ace (getvar "cecolor")
  (setvar "cmdecho" 0)
  (setvar "osmode" 0)
  (setvar "PELLIPSE" 0)
  (graphscr)
  (setq ang (getreal (strcat "\n输入轴侧<45>(度):")))
  (if (= ang nil)
    (setq ang 45.0
  (princ "\n选择图素:")
  (setq        a (ssget '((-4 . "<OR")
                   (0 . "line")
                   (0 . "circle")
                   (0 . "arc")
                   (0 . "text")
                   (-4 . "OR>")
        q (getpoint (strcat "\n输入标准点:"))
  (if a                                        ;if
    (progn
      (setq n         (sslength a)
            qx         (car q)
            qy         (cadr q)
            ang1 (* pi (/ ang 180))
            i         0
      (while (< i n)                        ;while-2
        (setq b        (ssname a i)
              c        (entget b)
        (if (equal '(0 . "LINE") (assoc 0 c)) ;if-1
          (progn
            (setq sx (- (cadr (assoc 10 c)) qx)
                  sy (- (caddr (assoc 10 c)) qy)
                  ex (- (cadr (assoc 11 c)) qx)
                  ey (- (caddr (assoc 11 c)) qy)
                  sx (+ (+ sx (* sy (cos ang1))) qx)
                  sy (+ (* sy (sin ang1)) qy)
                  ex (+ (+ ex (* ey (cos ang1))) qx)
                  ey (+ (* ey (sin ang1)) qy)
                  ps (cons 10 (list sx sy 0))
                  pe (cons 11 (list ex ey 0))
                  c  (subst ps (assoc 10 c) c)
                  c  (subst pe (assoc 11 c) c)
                  i  (+ i 1)
            (entmod c)
        )                                ;endif-1
        (if (equal '(0 . "CIRCLE") (assoc 0 c)) ;if-2
          (progn
                  r  (cdr (assoc 40 c))
                  r1 (* (sqrt (+ 1 (cos ang1))) r)
                  r2 (* (sqrt (- 1 (cos ang1))) r)
                  p  (list sx sy)
                  p1 (polar p (/ ang1 2) r1)
                  p2 (polar p (/ ang1 2) (- 0.0 r1))
                  p3 (polar p (/ (+ ang1 pi) 2) r2)
                  i  (+ i 1)
                  cl (cdr (assoc 8 c))
                  cc (cdr (assoc 62 c))
            (setvar "clayer" cl)
            (if        cc
              (command "setvar" "cecolor" cc)
              (setvar "cecolor" "BYLAYER")
            (command "_ellipse" p1 p2 p3)
            (entdel b)
        )                                ;endif-2
        (if (equal '(0 . "ARC") (assoc 0 c)) ;if-3
          (progn
                  as  (cdr (assoc 50 c))
                  ae  (cdr (assoc 51 c))
                  s   (list (cadr (assoc 10 c)) (caddr (assoc 10 c)))
                  a1  (polar s as r)
                  a2  (polar s ae r)
                  a1x (- (car a1) qx)
                  a1y (- (cadr a1) qy)
                  a2x (- (car a2) qx)
                  a2y (- (cadr a2) qy)
                  a1x (+ (+ a1x (* a1y (cos ang1))) qx)
                  a1y (+ (* a1y (sin ang1)) qy)
                  a2x (+ (+ a2x (* a2y (cos ang1))) qx)
                  a2y (+ (* a2y (sin ang1)) qy)
                  a1  (list a1x a1y)
                  a2  (list a2x a2y)
                  p   (list sx sy)
                  i   (+ i 1)
                  as  (angtos (- (angle p a1) (/ ang1 2)) 0 4)
                  ae  (angtos (- (angle p a2) (/ ang1 2)) 0 4)
            (if        cc
            (command "_ellipse" "a" p1 p2 p3 as ae)
            (entdel b)
        )                                ;endif-3
        (if (equal '(0 . "TEXT") (assoc 0 c)) ;if-4
          (progn
            (if        (= (cdr (assoc 72 c)) 5) ;if-5
              (setq ex (cadr (assoc 11 c))
                    ey (caddr (assoc 11 c))
              (setq ex (car (polar
                              (cdr (assoc 50 c))
                              1000
                    ey (cadr
                         (polar
                           (cdr (assoc 50 c))
                           1000
            )                                ;endif-5
                  ex (- ex qx)
                  ey (- ey qy)
                  dx (- (cadr (assoc 11 c)) qx)
                  dy (- (caddr (assoc 11 c)) qy)
                  dx (+ (+ dx (* dy (cos ang1))) qx)
                  dy (+ (* dy (sin ang1)) qy)
                  as (angle (list sx sy) (list ex ey))
                  d  '((0 . "TEXT")
                       (100 . "AcDbEntity")
                       (67 . 0)
                       (410 . "Model")
                       (8 . "0")
                       (100 . "AcDbText")
                       (10 115.157 111.17 0.0)
                       (40 . 2.5)
                       (1 . "35456465")
                       (50 . 0.0)
                       (41 . 0.6)
                       (51 . 0.0)
                       (7 . "Standard")
                       (71 . 0)
                       (72 . 0)
                       (11 0.0 0.0 0.0)
                       (210 0.0 0.0 1.0)
                       (100 . "AcDbText")
                       (73 . 0)
                  d  (subst (assoc 1 c) (assoc 1 d) d)
                  d  (subst (assoc 7 c) (assoc 7 d) d)
                  d  (subst (assoc 8 c) (assoc 8 d) d)
                  d  (subst (cons 10 (list sx sy 0)) (assoc 10 d) d)
                  d  (subst (cons 11 (list dx dy 0)) (assoc 11 d) d)
                  d  (subst (assoc 40 c) (assoc 40 d) d)
                  d  (subst (cons 50 as) (assoc 50 d) d)
                  d  (subst (assoc 67 c) (assoc 67 d) d)
                  d  (subst (assoc 73 c) (assoc 73 d) d)
                  i  (+ i 1)
            (if        (/= (cdr (assoc 72 c)) 5)
              (setq d (subst (assoc 72 c) (assoc 72 d) d)
            (entmake d)
            (entdel b)
        )                                ;endif-4
      )                                        ;while-2
    (princ "/n选择错误!")
  )                                        ;endif
  (setvar "cmdecho" abc)
  (setvar "osmode" bbb)
  (setvar "clayer" acl)
  (setvar "cecolor" ace)
  (princ)
发表于 2004-4-4 09:25:54 | 显示全部楼层
先把平面图形生成“面域”,然后用三维“拉伸”,再就是用“视图”转为你想要的轴测图。
发表于 2004-4-15 14:52:33 | 显示全部楼层
7楼:
加载时出现错误:
Loading C:\zc.lsp ...
Error: invalid dotted pair*Cancel*
不知为什么,能否改进?
发表于 2004-4-26 15:31:10 | 显示全部楼层
平面画好,用ddvpoint找好你的角度,用天正工具二的图形变线就可以了!
发表于 2004-4-26 19:48:43 | 显示全部楼层
轴测图也是平面图
发表于 2004-5-27 08:23:17 | 显示全部楼层
最初由 leochen 发布
[B]是画系统图吗?用这个lsp试试。
注意:把平面图复制好,炸开
             cl         cc  as         ... [/B]
用了一下,提示出错,是否复制时漏了什么东西,还是版本问题?我用2002版。
发表于 2004-5-27 09:40:15 | 显示全部楼层
我认为先画出3维立体图,然后再用轮廓转化成轴测图。
发表于 2004-5-27 09:42:23 | 显示全部楼层
好像没有这样简单的功能,一般在33d
发表于 2004-5-27 10:59:55 | 显示全部楼层
这个问题最好到给排水和暖通论坛去看看.
GMT+8, 2026-11-6 18:18 , Processed in 0.507497 second(s), 61 queries , Gzip On.
