查看: 919|回复: 2
[讨论]:求助 :怎么理解这个功能
发表于 2004-4-1 00:15:12 | 显示全部楼层 |阅读模式
To set up a Microsoft Excel spreadsheet to use with AutoCAD
From Microsoft Excel, open the workbook or spreadsheet that you want to access from AutoCAD.
Select a range of cells to function as a database table.
Enter a name for the range of cells in the Name Box, then press ENTER.
Repeat steps 2 and 3, if desired, to specify additional database tables.
From the File menu (Microsoft Excel), choose Save.
Note  Microsoft Excel is not a true database management system. In order to access Excel data from within AutoCAD, you must first specify at least one named range of Excel cells to function as a database table. Each named range of cells that you specify within a spreadsheet is treated as an individual table by AutoCAD.
这是ACAD2005的功能介绍,怎么理解上面的“Select a range of cells to function as a database table.”啊,可以做吗,怎么做?
发表于 2004-4-1 10:27:17 | 显示全部楼层
  这个容易理解,就是让你选择Excel中的要粘帖的表格单元(范围),只有选中的表格单元才能粘到Autocad2005中呀!不是整个文件。粘贴后的(Autocad图元)的表格是符合Autocad2005表格样式格式的表格。
发表于 2004-4-1 11:01:33 | 显示全部楼层
现在还有这个功能啊!真的不错
GMT+8, 2026-11-5 16:33 , Processed in 0.370973 second(s), 36 queries , Gzip On.
