查看: 892|回复: 1
[求助] [求助]:关于VLisp嵌套对话框的问题
发表于 2004-4-1 13:29:54 | 显示全部楼层 |阅读模式
用VLisp编辑嵌套对话框,如何控制返回上一层对话框?
发表于 2004-4-5 09:06:53 | 显示全部楼层
请参考这个小例子:
(defun c:test ()
  (setq index (load_dialog (findfile "dial.dcl")))
  (if (not (new_dialog "dqt" index))(exit))
  (mode_tile "nextb" 2)
  (action_tile"nextb" "(next)")
  (start_dialog)
(defun next ()
  (if (not (new_dialog "next" index))(exit))
  (start_dialog)
dqt : dialog { label="First Dialog Box";
  : button {
    label = "Next";
    key = "nextb";
  ok_cancel;
next : dialog {label ="Second Dialog box";
  ok_only;
GMT+8, 2026-11-4 19:51 , Processed in 0.713139 second(s), 34 queries , Gzip On.
