查看: 891|回复: 4
[寻找]:Bentley AutoPLANT Structural 2004 Edition
发表于 2004-4-1 19:33:33 | 显示全部楼层 |阅读模式
Bentley AutoPLANT Structural is a set of AutoCAD-based applications that provide the structural designer / engineer with a powerful 3D steel modeling, detailing and fabrication tool for steel-framed building construction and all shape-based construction tasks.
Licensed modules include:
Bentley AutoPLANT Structural Modeler - Easy-to-use, steel modeling application, suitable for fast three-dimensional modeling of new or existing structures.
Bentley AutoPLANT Structural Engineering - Incorporates all of the functionality of Structural Modeler with the added ability to produce detailed frame drawings and comprehensive assembly lists from the completed model.
Bentley AutoPLANT Structural Detailer - Incorporates all of the functionality of Structural Engineering with the powerful "Detail Center" for automating the management and production of detailed fabrication and assembly drawings.
Pre-requisites: AutoCAD 2000, or 2000i, or 2002 or 2004 or Architectural Desktop 3.3 or Building Systems 3.0
All modules are included in one downloadable install file. Each module is licensed independently.
[B]谁有下载地址呀!发上来让大家尝尝鲜。[/B][/SIZE][/COLOR]
发表于 2005-2-13 17:59:23 | 显示全部楼层
不管哪个版本,好像都没有结构部分的组件。全是DEMO版本的。
发表于 2005-2-16 09:08:23 | 显示全部楼层
只是没有破解,您要到时可以给您
QQ195316587
NCPCPJF·YAHOO。COM。CN
我试用了一下还可以
用2.01的特别文件可以使用很长时间,但是设备建模不能太多
发表于 2005-2-26 18:23:07 | 显示全部楼层
此软件下载不容易,想找到也南。我找了很久也找不到。不知那位有AutoPlant P※ID2004?
发表于 2005-3-1 17:21:44 | 显示全部楼层
最初由 mjlmjl 发布
[B]此软件下载不容易,想找到也南。我找了很久也找不到。不知那位有AutoPlant P※ID2004? [/B]
到9iv.com(E维)去下载,用bentley来搜索
GMT+8, 2026-11-3 13:59 , Processed in 0.507798 second(s), 41 queries , Gzip On.
