查看: 648|回复: 0
[VBA程序]:将模型空间实体信息输出到EXCEL
发表于 2004-4-18 11:56:09 | 显示全部楼层 |阅读模式
这里只输出了对象名,颜色,层名,线型
Sub outexcel()
Dim xlApp As Excel.Application
Dim xlbook As Excel.Workbook
Dim xlSheet As Excel.Worksheet
On Error Resume Next
Set xlApp = GetObject(, "excel.application")
If Err <> 0 Then
Err.Clear
Set xlApp = CreateObject("excel.application")
If Err <> 0 Then
MsgBox "无法启动excel"
Exit Sub
End If
End If
Set xlbook = xlApp.Workbooks.Add
Set xlSheet = xlbook.ActiveSheet
xlApp.Visible = True
xlSheet.Cells(1, 1) = "对象名"
xlSheet.Cells(1, 2) = "颜色"
xlSheet.Cells(1, 3) = "层名"
xlSheet.Cells(1, 4) = "线型"
Dim i As Integer
For i = 0 To ThisDrawing.ModelSpace.Count - 1
With ThisDrawing.ModelSpace(i)
xlSheet.Cells(i + 2, 1) = .ObjectName
xlSheet.Cells(i + 2, 2) = .Color
xlSheet.Cells(i + 2, 3) = .Layer
xlSheet.Cells(i + 2, 4) = .Linetype
End With
Next
End Sub
GMT+8, 2026-11-3 08:30 , Processed in 0.424500 second(s), 32 queries , Gzip On.
