查看: 639|回复: 0
[ARX函数]:这次又是我输了5555
发表于 2004-4-22 17:14:22 | 显示全部楼层 |阅读模式
最近编了几个有关CAD数据库操作的程序,结果都是出现同样的错误,提示为:
E:\xgh\VC工程\OperateDb\OperateDb.cpp(209) : error C2601: 'initApp' : local function definitions are illegal
E:\xgh\VC工程\OperateDb\OperateDb.cpp(235) : error C2601: 'unloadApp' : local function definitions are illegal
E:\xgh\VC工程\OperateDb\OperateDb.cpp(241) : error C2598: linkage specification must be at global scope
E:\xgh\VC工程\OperateDb\OperateDb.cpp(242) : error C2601: 'acrxEntryPoint' : local function definitions are illegal
E:\xgh\VC工程\OperateDb\OperateDb.cpp(258) : fatal error C1004: unexpected end of file found
有关的代码是:
void initApp(){
acedRegCmds->addCommand ("OPERATEDB_COMMAND",
                        "CREATEDB",
         "CREATEDB",
          ACRX_CMD_MODAL,
       createDb);
void unloadApp(){
acedRegCmds->removeGroup("OPERATEDB_COMMAND");
acedRegCmds->removeGroup("LongTransaction_COMMAND");
extern"C" AcRx::AppRetCode
acrxEntryPoint(AcRx::AppMsgCode msg, void* appid)
switch (msg)
  case AcRx::kInitAppMsg:
  acrxDynamicLinker->unlockApplication(appid);
  acrxDynamicLinker->registerAppMDIAware(appid);
  initApp();
  break;
  case AcRx::kUnloadAppMsg:
  unloadApp();
  break;
  default:
   break;
  return AcRx::kRetOK;
而这些函数我都在前面声明了啊,这是怎么回事啊????
请高手指教,谢谢!
GMT+8, 2026-11-3 08:05 , Processed in 0.494148 second(s), 32 queries , Gzip On.
