查看: 1393|回复: 1
[ARX函数]:接口问题,高手请进!
发表于 2002-11-8 19:13:18 | 显示全部楼层 |阅读模式
请看,我从别处抄来的程序,是应用com接口来创建菜单。但运行到标志位置就出现“未处理的异常E06d7363(E06D7363H)地址:77E7E8BBh”错误:
部分代码如下:
IAcadMenuBar                AcadMenuBar;
IAcadPopupMenus                AcadPopupMenus;
IAcadPopupMenu                AcadPopupMenu;
//创建AcadMenuBar接口
AcadMenuBar.AttachDispatch(AcadApplication.GetMenuBar());
//获得菜单栏的个数
NumOfMenu=AcadMenuBar.GetCount();
//创建AcadPopupMenus接口
AcadPopupMenus.AttachDispatch(AcadMenuGroup.GetMenus());
//创建AcadPopupMenu接口
AcadPopupMenu.AttachDispatch(AcadPopupMenus.Add("文具(&Q)"));
//就在上面这一句就出错了!
我想是不是因为地址冲突了呢?但我不知道是为什么,怎么冲突了,怎么解决,请高手帮忙看一下!
已领礼包: 145个
发表于 2002-11-8 19:23:08 | 显示全部楼层
给你贴篇用ACTIVEX创建POP菜单的资料,你看看,讲的比较详细了。
你的问题解决后,希望把完整的代码贴到论坛和大家分享。
  1. [FONT=courier new]
  2. How to create a pull-down popup menu through ActiveX?
  3. ID    17818
  4. Applies to:    AutoCAD
  5. This document is part of    ObjectARX   COM-ActiveX Interfaces   Menus and Toolbars   MFC
  6. Question
  7. I'm trying to access the menu groups and popup menus exposed through Automation,
  8. but there are so many different objects, menu groups, menu group, popup menus,
  9. and popup menu item. Is there a client sample in C++?
  10. Answer
  11. It can be confusing to sort through so many objects and use them. A good way to
  12. understand their relationships is to look at the Automation Object Model because
  13. it depicts a hierarchical relationship among the menu objects as well as with
  14. others.
  15. The following code creates a dialog-based client application, assigns a button
  16. to handle "Start Acad", and assigns a button to handle "Add a menu item". (The
  17. following code assumes you know how to create a dialog-based MFC application.)
  18. In the dialog's header file, the following member variables were declared (you
  19. need to import interface classes from the acad.tlb file using the ClassWizard,
  20. Add class..., choose From type library. Be sure not to use #import).
  21. IAcadApplication m_IApp;
  22.         IAcadDocument         m_IDoc;
  23.         IAcadModelSpace  m_IMSpace;
  24.
  25.         IAcadMenuGroups         m_IMenuGrps;
  26.         IAcadMenuGroup                m_IMenuGrp;
  27.         IAcadPopupMenus         m_IPopupMenus;
  28.         IAcadPopupMenu                m_IPopupMenu;
  29.         IAcadPopupMenuItem        m_IPopupMenuItem;
  30. In the dialog's cpp file, add the following (2) handlers:
  31. //
  32. // This function starts Acad and initialize the appropriate
  33. // interface objects
  34. //
  35. void CClientDlg::OnStartAcad()
  36. {
  37.         HRESULT hr = NOERROR;
  38.         CLSID clsid;
  39.         LPUNKNOWN pUnk = NULL;
  40.         LPDISPATCH pDisp = NULL;
  41.         BeginWaitCursor();
  42.         CoInitialize(NULL);
  43.         hr = ::CLSIDFromProgID(L"AutoCAD.Application", &clsid);
  44.         if (SUCCEEDED(hr))
  45.         {
  46.                 if(::GetActiveObject(clsid, NULL, &pUnk) == S_OK)
  47.                 {
  48.                         VERIFY(pUnk->QueryInterface(IID_IDispatch, (LPVOID*)
  49. &pDisp) == S_OK);
  50.                         m_IApp.AttachDispatch(pDisp);
  51.                         pUnk->Release();
  52.                 }
  53.                 else
  54.                         VERIFY(m_IApp.CreateDispatch(clsid) == TRUE);
  55.
  56.                 m_IApp.SetVisible(TRUE);
  57.                 pDisp = m_IApp.GetActiveDocument();
  58.                 m_IDoc.AttachDispatch(pDisp);
  59.                 pDisp = m_IDoc.GetModelSpace();
  60.                 m_IMSpace.AttachDispatch(pDisp);
  61.         }
  62.         else
  63.                 AfxMessageBox("Acad.Application is not registered!");
  64.         // remember the you need to call CoUninitialize(); somewhere
  65.         // I would do it in the destructor of the dialog
  66.         EndWaitCursor();
  67. }
  68. //
  69. // This function adds a popup menu to the exist row of popup menus
  70. // displayed in the menu bar.
  71. //
  72. // Note: The popup menus and menu items that we are adding
  73. // through Automation, are in memory only. They are not
  74. // saved in any menu files, no persistent in another word.
  75. //
  76. void CClientDlg::OnAddMenuButton()
  77. {
  78.         // get all the menu groups
  79.         LPDISPATCH pDisp = m_IApp.GetMenuGroups();
  80.         m_IMenuGrps.AttachDispatch(pDisp);
  81.         // get to the menu group that we're interested
  82.         VARIANT var;
  83.         var.vt = VT_I4;
  84.         var.lVal = 0;
  85.         pDisp = m_IMenuGrps.Item(var);
  86.         m_IMenuGrp.AttachDispatch(pDisp);
  87.         // get the popup menus in the menu group
  88.         pDisp = m_IMenuGrp.GetMenus();
  89.         m_IPopupMenus.AttachDispatch(pDisp);
  90.         long cnt = m_IPopupMenus.GetCount();
  91.         VARIANT  vtIndex;
  92.         vtIndex.vt = VT_I4;
  93.         vtIndex.lVal = cnt + 1;
  94.         // append a popup menu to the popup menus
  95.         const char myPopupMenuName[] = "TestPopupMenu";
  96.         pDisp = m_IPopupMenus.Add(myPopupMenuName);
  97.         m_IPopupMenu.AttachDispatch(pDisp);
  98.         m_IPopupMenus.InsertMenuInMenuBar(myPopupMenuName, vtIndex);
  99.         // append a menu item to the popup menu we added
  100.         // notice the last parameter of AddMenuItem is for
  101.         // a command
  102.         vtIndex.lVal = 0;
  103.         pDisp = m_IPopupMenu.AddMenuItem(vtIndex, "TestItem", "Regen ");
  104.         m_IPopupMenuItem.AttachDispatch(pDisp);
  105. }
  106. Removing menu bar and items are just as easy. You can call
  107. RemoveMenuFromMenuBar() to remove a popup menu, for example.[/FONT]
GMT+8, 2026-11-3 01:42 , Processed in 0.472348 second(s), 34 queries , Gzip On.
