查看: 812|回复: 8
[求助]:请问如何安装viz 2005(破解版)啊?
发表于 2004-5-3 02:34:51 | 显示全部楼层 |阅读模式
发表于 2004-5-3 12:27:54 | 显示全部楼层
你有注册码
 楼主| 发表于 2004-5-3 12:58:14 | 显示全部楼层
可惜没有注册码,软件里面提示的安装方法为:
install the app
   - choose Network Installation
   - enter your localhost as server name
   - then install the network license manager and configure it
   - produce a license file with the License Generator
但不太懂。
发表于 2004-5-4 22:31:40 | 显示全部楼层
 楼主| 发表于 2004-5-5 10:32:36 | 显示全部楼层
哇,真是太感谢了
已领礼包: 7993个
发表于 2004-5-5 10:47:41 | 显示全部楼层
不知你夷文程度如何?
1) Install, choose Network and Use any serial you want
2) install Autodesk Network License Manager located in nlm dir.
3) copy Licpath.lic into \Autodesk Network License Manager\License\
4) Start ..\Autodesk Network License Manager\lmtools.exe
5) into "Service/License File" select - Configuration using Services
   into "Config Services" - set Service Name "Viz 2005"
                          - set Path to the lmgrd.exe file
         "..\Autodesk Network License Manager\lmgrd.exe"
                           - set Path to the license file
         "..\Autodesk Network License Manager\License\License.txt"
                           - set Path to the debug log file
         "..\Autodesk Network License Manager\License\debug.txt
      - select "Start Server at Power Up" and "Use Services"
      - Save service
    into "Start/Stop/Reread" select "Viz 2005" and restart the server
我是连猜带蒙安装成乐。
发表于 2004-8-28 17:01:01 | 显示全部楼层
不错,简化版本和2CD版本的破解方法
我看简化版里面的E文做,成功是成功了,但是unregistered verson应该是没有完全激活吧,可能下次还是要启动服务才能运行的
- Save service
发表于 2004-8-29 11:27:49 | 显示全部楼层
i use that instruction above and success,  you should copy that licpath.lic to root of viz, not just in Autodesk Network License Manager\License\
发表于 2004-8-29 14:50:41 | 显示全部楼层
还是安装完整版的要好一点,简化版的都不稳定了!经常会出错了!
GMT+8, 2026-11-4 17:26 , Processed in 0.912693 second(s), 48 queries , Gzip On.
