查看: 1114|回复: 3
[建议]:V9出来了?
发表于 2002-11-17 15:39:31 | 显示全部楼层 |阅读模式
据说V9也问世了?那位大侠介绍一下?
发表于 2002-11-18 13:15:14 | 显示全部楼层
V9应该还没释出,不过BENTLEY.MicroStation.V8.1 RC1已出来了(v8.00.07.32)
          The Release Candidate designates Bentley's final step in preparing a
         product for commercial availability. A Release Candidate is a certified
         and supported version and may be suitable for production use. However,
         a Release Candidate has not passed the necessary criteria that defines
         readiness across a product line and, therefore, may not be fully
         compatible with existing versions of dependent applications or hardware
         devices. Release Candidates provide opportunities to make final
         preparations for full-scale deployment, including designing and
         implementing standards or adjusting workflows that take advantage of
         new functionality.
         Before you begin, please note the following:
         A Release Candidate is fully certified and supported by Bentley
         Technical Support.
         A Release Candidate may be used in production but unless explicitly
         noted, due to some cross-product dependencies, you may experience
         compatibility problems when running this version with other Bentley or
         third-party applications. IN OTHER WORDS, beware, this RC may not be
         compatible with ANY plugins, aside from what is released from this
         point on. There may be more than one Release Candidate for a product
         before it reaches Commercial Release.
发表于 2002-11-23 09:51:50 | 显示全部楼层
我没看到。
发表于 2002-11-23 10:47:05 | 显示全部楼层
哪里 能 download MicroStation V8 , 交流
友情帮助
GMT+8, 2026-11-2 21:40 , Processed in 0.645607 second(s), 38 queries , Gzip On.
