查看: 1571|回复: 3
[分享]:C#+MicroStationCOM读取DGN文件
发表于 2004-5-12 11:34:25 | 显示全部楼层 |阅读模式
刚从Bentley讨论组下载了这个C#读取DGN文件的程序。共享给大家。
发表于 2004-5-12 11:50:25 | 显示全部楼层
转载原文
I know this is not a traditional MDL topic, but I have posted the zip file dgnlist.zip up on the ftp site
(ftp://ftp.bentley.com/pub/outgoing/dgnlist.zip). All the code, documentation and support files are there to build the
dgnlist console application in VS.NET. Please read the documentation, etc for what I had used to build the application
and how the code works. There are some areas and elements of the code I have left out on purpose so you can fill in the
blanks from my examples. Have fun. You may need to reset the paths for the project/solution to get all the files to show
up in the solution browser. Let me know if there are any problems. Oh BTW, no traditional MDL calls in this code. Just
pure C#.
Mark Anderson should also have the same and my distribute through other channels.
Jerry Walter
Bentley Systems, Inc.
发表于 2004-5-12 12:58:50 | 显示全部楼层
下不了呀
发表于 2004-5-12 13:13:20 | 显示全部楼层
可以下。
没有试这个例子,不过以前自己测试的时候,运行c#程序必须打开msv8 才行。而且如果要有交互操作,就比较麻烦了。感觉实用价值不大,所以就不再深究了。
如果能支持嵌入式开发,或者组件式的,那还差不多。
GMT+8, 2026-11-3 19:27 , Processed in 0.699058 second(s), 39 queries , Gzip On.
