查看: 721|回复: 1
[求助]:问题一个,解决不了,很着急,求大家帮忙
发表于 2004-5-14 16:04:30 | 显示全部楼层 |阅读模式
我用micorstation连接oracle 8i数据库的时候出现以下错误提示:
The current micorstation database client files require an oracle 8i client.please check the Oracle Home, system path and micorostation database client files(orsevrd.dll, orserver.rsc and oralddlm.ma).
请问是怎么回事?
发表于 2004-5-14 16:29:52 | 显示全部楼层
Solution: This message can be obtained when the MS_ORACLE_HOME directory is not set to the proper location. Check the ../microstation/config/appl/sdodgn.cfg file for this variable, if nessecary, redirect/reset the variable definition to point to the proper Oracle Home.
While the Oracle 9i client has been installed, a critical file is missing. Maybe reinstalling the Oracle client will resolve the issue.
重新安装Oracle客户端,或者检查../microstation/config/appl/sdodgn.cfg文件,设置正确的Oracle Home的目录
GMT+8, 2026-11-3 20:06 , Processed in 0.515561 second(s), 34 queries , Gzip On.
