查看: 406|回复: 0
[求助]:Sever-U 日志里面出现大量这个信息,怎么一回事
发表于 2004-5-14 17:25:15 | 显示全部楼层 |阅读模式
[7] Fri 14May04 16:28:50 - Sock ID=61 getsockopt(264,SOL_SOCKET,SO_ACCEPTCONN,0x00F5FCF8,0x00F5FCF4) --> 0 (OK)
[7] Fri 14May04 16:31:52 - Sock ID=61 getsockopt(264,SOL_SOCKET,SO_ACCEPTCONN,0x00F5FCF8,0x00F5FCF4) --> 0 (OK)
[7] Fri 14May04 16:34:52 - Sock ID=61 getsockopt(264,SOL_SOCKET,SO_ACCEPTCONN,0x00F5FCF8,0x00F5FCF4) --> 0 (OK)
[7] Fri 14May04 16:37:52 - Sock ID=61 getsockopt(264,SOL_SOCKET,SO_ACCEPTCONN,0x00F5FCF8,0x00F5FCF4) --> 0 (OK)
[7] Fri 14May04 16:40:52 - Sock ID=61 getsockopt(264,SOL_SOCKET,SO_ACCEPTCONN,0x00F5FCF8,0x00F5FCF4) --> 0 (OK)
[7] Fri 14May04 16:43:52 - Sock ID=61 getsockopt(264,SOL_SOCKET,SO_ACCEPTCONN,0x00F5FCF8,0x00F5FCF4) --> 0 (OK)
[7] Fri 14May04 16:46:52 - Sock ID=61 getsockopt(264,SOL_SOCKET,SO_ACCEPTCONN,0x00F5FCF8,0x00F5FCF4) --> 0 (OK)
[7] Fri 14May04 16:49:52 - Sock ID=61 getsockopt(264,SOL_SOCKET,SO_ACCEPTCONN,0x00F5FCF8,0x00F5FCF4) --> 0 (OK)
[7] Fri 14May04 16:52:52 - Sock ID=61 getsockopt(264,SOL_SOCKET,SO_ACCEPTCONN,0x00F5FCF8,0x00F5FCF4) --> 0 (OK)
[7] Fri 14May04 16:55:52 - Sock ID=61 getsockopt(264,SOL_SOCKET,SO_ACCEPTCONN,0x00F5FCF8,0x00F5FCF4) --> 0 (OK)
[7] Fri 14May04 16:58:52 - Sock ID=61 getsockopt(264,SOL_SOCKET,SO_ACCEPTCONN,0x00F5FCF8,0x00F5FCF4) --> 0 (OK)
[7] Fri 14May04 17:01:52 - Sock ID=61 getsockopt(264,SOL_SOCKET,SO_ACCEPTCONN,0x00F5FCF8,0x00F5FCF4) --> 0 (OK)
[7] Fri 14May04 17:04:52 - Sock ID=61 getsockopt(264,SOL_SOCKET,SO_ACCEPTCONN,0x00F5FCF8,0x00F5FCF4) --> 0 (OK)
[7] Fri 14May04 17:07:52 - Sock ID=61 getsockopt(264,SOL_SOCKET,SO_ACCEPTCONN,0x00F5FCF8,0x00F5FCF4) --> 0 (OK)
[7] Fri 14May04 17:10:52 - Sock ID=61 getsockopt(264,SOL_SOCKET,SO_ACCEPTCONN,0x00F5FCF8,0x00F5FCF4) --> 0 (OK)
[7] Fri 14May04 17:13:52 - Sock ID=61 getsockopt(264,SOL_SOCKET,SO_ACCEPTCONN,0x00F5FCF8,0x00F5FCF4) --> 0 (OK)
[7] Fri 14May04 17:16:52 - Sock ID=61 getsockopt(264,SOL_SOCKET,SO_ACCEPTCONN,0x00F5FCF8,0x00F5FCF4) --> 0 (OK)
[7] Fri 14May04 17:19:53 - Sock ID=61 getsockopt(264,SOL_SOCKET,SO_ACCEPTCONN,
晕啊,
GMT+8, 2026-11-6 19:50 , Processed in 0.276890 second(s), 30 queries , Gzip On.
