查看: 1125|回复: 1
[弹指神通]:对话框中toolbar显示tooltips
发表于 2002-11-19 10:40:16 | 显示全部楼层 |阅读模式
绝对可以用,不用doc/view支持
How to display tooltips for a toolbar in a dialog
This article was contributed by Randy More.
It is relatively easy to place a toolbar in a dialog box, but I had a hard time making the tooltips appear since none of the TTN_xxxx message handlers are present in a CDialog derived class. This article describes a simple technique for getting tooltips when you have a toolbar in a dialog. It also gives a brief overview of the steps involved in adding a toolbar to a dialog box.
Step 1
In the dialog's header file you must add a CToolBar instance and an entry in the message map to handle the tooltip messages.
protected:
     CToolBar cToolBar;
at the bottom of the wizard generated message map entries add:
//}}AFX_MSG
afx_msg BOOL OnToolTipText(UINT nID, NMHDR* pNMHDR, LRESULT* pResult);
DECLARE_MESSAGE_MAP()
Step 2
In dialog's implementation file add the following to the end of OnInitDialog to show the toolbar.
//add the tool bar to the dialog
cToolBar.Create(this);
cToolBar.LoadToolBar(IDR_TOOLBAR);
cToolBar.ShowWindow(SW_SHOW);
cToolBar.SetBarStyle(CBRS_ALIGN_TOP | CBRS_TOOLTIPS | CBRS_FLYBY);
RepositionBars(AFX_IDW_CONTROLBAR_FIRST, AFX_IDW_CONTROLBAR_LAST, 0);
At the bottom of the message map add the following:
FX_MSG_MAP
ON_NOTIFY_EX_RANGE(TTN_NEEDTEXTW, 0, 0xFFFF, OnToolTipText)
ON_NOTIFY_EX_RANGE(TTN_NEEDTEXTA, 0, 0xFFFF, OnToolTipText)
END_MESSAGE_MAP()
Finally add the message handler method as entered in the message map:
BOOL CToolBarTipTestDialog::OnToolTipText(UINT, NMHDR* pNMHDR, LRESULT* pResult)
     ASSERT(pNMHDR->code == TTN_NEEDTEXTA || pNMHDR->code == TTN_NEEDTEXTW);
     // if there is a top level routing frame then let it handle the message
     if (GetRoutingFrame() != NULL) return FALSE;
     // to be thorough we will need to handle UNICODE versions of the message also !!
     TOOLTIPTEXTA* pTTTA = (TOOLTIPTEXTA*)pNMHDR;
     TOOLTIPTEXTW* pTTTW = (TOOLTIPTEXTW*)pNMHDR;
     TCHAR szFullText[512];
     CString strTipText;
     UINT nID = pNMHDR->idFrom;
     if (pNMHDR->code == TTN_NEEDTEXTA && (pTTTA->uFlags & TTF_IDISHWND) ||
         pNMHDR->code == TTN_NEEDTEXTW && (pTTTW->uFlags & TTF_IDISHWND))
          // idFrom is actually the HWND of the tool
          nID = ::GetDlgCtrlID((HWND)nID);
     if (nID != 0) // will be zero on a separator
          AfxLoadString(nID, szFullText);
          strTipText=szFullText;
#ifndef _UNICODE
          if (pNMHDR->code == TTN_NEEDTEXTA)
               lstrcpyn(pTTTA->szText, strTipText, sizeof(pTTTA->szText));
          else
               _mbstowcsz(pTTTW->szText, strTipText, sizeof(pTTTW->szText));
#else
               _wcstombsz(pTTTA->szText, strTipText,sizeof(pTTTA->szText));
          else
               lstrcpyn(pTTTW->szText, strTipText, sizeof(pTTTW->szText));
#endif
          *pResult = 0;
          // bring the tooltip window above other popup windows
          ::SetWindowPos(pNMHDR->hwndFrom, HWND_TOP, 0, 0, 0, 0,SWP_NOACTIVATE|
               SWP_NOSIZE|SWP_NOMOVE|SWP_NOOWNERZORDER); return TRUE;
发表于 2002-11-22 20:18:23 | 显示全部楼层
the article ought to the subject of vc ++
GMT+8, 2026-11-3 06:06 , Processed in 0.534250 second(s), 34 queries , Gzip On.
