查看: 1092|回复: 0
[求助]:为什么对三维物体的放大,旋转可以,但措切就不行呢
发表于 2004-5-15 17:03:29 | 显示全部楼层 |阅读模式
re
我的代码是这样的,
#include "StdAfx.h"
#include "StdArx.h"
void tss()
        int i,j        ;                        // Row of ads_matrix
        ads_matrix xform;        // The transformation matrix
        ads_name ssGrp;                // The entities that make up transform SS
        int rc;                                // Return code
        ads_real d,s;                // Scale Factor
        // Select the entities
        acedPrompt("\nSelect enties to scale (transfrom) ");
        rc = acedSSGet(NULL, NULL, NULL, NULL, ssGrp);
        if(rc != RTNORM)
                acutPrintf("\nEmpty or invalid selection set ");
                return;
        // Input the scale factor
        acedInitGet(RSG_NONULL + RSG_NONEG + RSG_NOZERO, NULL);
        acedGetReal("\n请输入x对z的错切量 : ", &d);
        acedGetReal("\n请输入y对z的错切量: ", &s);
        // Initialize the matrix
        ident_init(xform);
        // Apply the scaling factor
        // to the matrix
        for(i = 0; i <= 3; i++)
                for(j = 0; j <= 3; j++)
                xform[j] = 0.0;
        xform[0][0] = 1.0;
        xform[1][1] = 1.0;
    xform[2][2] = 1.0;
        xform[2][0] = d;
        xform[2][1] = s;
        rc = acedXformSS(ssGrp, xform);
        if(rc != RTNORM)
                acutPrintf("\n转换失败. ");
        acedSSFree(ssGrp);
最终还是转换失败,请各位帮忙
GMT+8, 2026-11-22 07:58 , Processed in 0.246897 second(s), 10 queries , Gzip On, File On.
