查看: 818|回复: 0
[LISP程序]:批量修改多图形文件文本
发表于 2004-5-17 08:05:16 | 显示全部楼层 |阅读模式
该程序可同时批量处理所有打开的图形(DWG)文件中的文本, 将 "Enzed" 修改为 "Parker"
[php]
(defun c:test ()
  ;(vl-load-com)
  (vlax-for i (vla-get-Documents (vlax-get-acad-object))
    (vlax-for j (vla-get-modelspace i)
      (if (= "AcDbText" (vla-get-objectname j))
        (if (= "Enzed" (vla-get-textstring j))
          (vla-put-textstring j "Parker")
    (vla-regen i acallviewports)
[/php]
GMT+8, 2026-11-4 22:53 , Processed in 1.799429 second(s), 32 queries , Gzip On.
