查看: 634|回复: 0
[VBA程序]:如果做交叉递增的圆点?
发表于 2004-5-18 13:52:51 | 显示全部楼层 |阅读模式
我现在参照老大们的意思画出了递增的圆点,可还有点问题想请帮忙,能否帮我解决?
登录/注册后可看大图
图中1.2.3.4是递增的圆点.
Option Explicit
Public length, lengthn1, ptdis, mmaxr, mecha, n, p, q, l As Double
Public centerpt(0 To 2) As Double
Sub DengchaFen()
Dim radius, radius1 As Double
Dim lengthn As Integer
Dim circ As AcadCircle
If q = 0 Then
length = InputBox(":输入长度")
ptdis = InputBox("输入网点间距")
n = InputBox("输入绘制行数")
lengthn1 = length / (3 ^ (0.5) * ptdis)
p = 1
l = 1
End If
lengthn = Int(lengthn1)
radius = InputBox("输入最小点直径") / 2
radius1 = radius
mmaxr = InputBox("输入最大点直径") / 2
mecha = (mmaxr - radius) / lengthn
Do
    Do
         Set circ = ThisDrawing.ModelSpace.AddCircle(centerpt, radius)
         centerpt(0) = centerpt(0) + 3 ^ (0.5) * ptdis
         radius = radius + mecha
         q = q + 1
    Loop While centerpt(0) <= length
    centerpt(1) = centerpt(1) + ptdis
    centerpt(0) = 0
    radius = radius1
Loop While centerpt(1) <= (n * p - 1) * ptdis + ptdis / 4
dengcha.Show
ThisDrawing.Application.ZoomExtents
End Sub
我原来的代码做出来的效果如下
登录/注册后可看大图
我希望能在画红处做出递增的圆点
GMT+8, 2026-11-2 16:45 , Processed in 0.379012 second(s), 32 queries , Gzip On.
