查看: 1492|回复: 2
[求助] [求助]:谁替我看看?
发表于 2002-11-20 15:11:34 | 显示全部楼层 |阅读模式
Public Sub try()
Dim pickObj As AcadEntity
Dim pickPnt As Variant
Dim length As Variant
Dim B As Variant
Dim c As Variant
Dim point(0 To 2) As Variant
'Dim poin As Variant
Dim PROMPT1 As String
PROMPT1 = vbCrLf & "Enter the  point of : "
'point = ThisDrawing.Utility.GetPoint(, PROMPT1)
ThisDrawing.Utility.GetEntity pickObj, pickPnt, "choose curve"
point(0) = 225.4166
point(1) = 117.943
point(2) = 0
length = GetCurveLength(pickObj)
MsgBox length
B = GetCurvePointAtDist(pickObj, 10#)
MsgBox B(0)
c = GetCurveDistAtPoint(pickObj, point)
MsgBox c
End Sub
'VLAX 中vlax-curve-getDistAtPoint 如直接在线上取点则
'能返回到起点的长度,若在线上量出坐标输入则得不到结果,好象是
'小数点位数问题,如不是交互输入,在程序中如何解决?
发表于 2002-11-22 11:31:36 | 显示全部楼层
请问是否有如下函数:
 楼主| 发表于 2002-11-22 16:18:24 | 显示全部楼层
这个已通过别的渠道解决了,但是
如何通过限制小数位解决呢,?
GMT+8, 2026-11-3 07:47 , Processed in 0.412622 second(s), 36 queries , Gzip On.
