查看: 412|回复: 0
[转贴]:照明电器国家标准、行业标准目录
发表于 2004-5-19 08:43:12 | 显示全部楼层 |阅读模式
*-*b *-*b
一、       国家标准
GB 2313-1993  管形荧光灯镇流器一般要求和安全要求
Ballasts for tubular fluorescent lamps general and safety  requirements
GB/T 3978-1994  标准照明体及照明观测条件
Standard illuminants and illuminating-viewing conditions
GB/T 5700-1985  室内照明测量方法
Measurement methods for interior lightimg
GB 7248-1987  电光源的安全要求
Safety requirements of electrical light source
GB/T 7249-1987  普通照明灯泡的最大外形尺寸
Maximum lamp outlines for general lightimg lamps
GB/T 7451-1987  电光源名词
Electric light source vocabulary
GB/T 7922-1987  照明光源颜色的测量方法
Methods of measuring the colour of lignt source
GB/T 8417-1987  灯光信号颜色
Colors of light signals
GB 10681-1989  普通照明灯泡
General service incandescent lamp
GB 10682-1989  普通照明用管形荧光灯
Tubular fluorescent lamps for general liglitimg
GB 10976-1989  正面放映设备  银幕照度测量方法
Front projection equipment  Method for measuring screen illumination
GB/T 11470-1989 电光源产品质量分等分级指标
The criteria of quality-control and classification of electric lamps
GB/T 13259-1991 高压钠灯泡
High pressure sodium lamps
GB/T13434-1992 高压钠灯泡特性的测试方法
Test method for H.P.S. lamps
GB/T 14044-1993 管形荧光灯镇流器性能要求
Ballasts for tubular fluorescent lamps performance requirements
GB 14045-1993 放电灯(管形荧光灯除外)用镇流器的一般要求和安全要求
Ballasts for discharge lamps (excluding tubular fluorescent lamps)general and safety requirements
GB/T 14046-1993 铁路信号灯泡
Lamps for railway signal
GB/T 14094-1993 卤钨灯
Tungsten halogen lamps
GB 14196-1993 普通照明灯泡的安全要求
Safety requirements for tungsten filament lamps for domestic and similar general lightimg purposes
GB 15039-1994  发光强度、总光通量标准灯泡
Standard lamps for the  measurment of luminous intensity and luminous flux
GB 15040-1994 普通测光标准灯泡
Photometric standard lamp for general lightimg service
GB/T 15041 –1994 高压短弧氙灯
High pressure xenon short arc lamp
GB/T 15042-1994 高压钠灯泡用镇流器性能要求
Ballast for high pressure sodium lamp property requirement
GB/T 15043-1994 白炽灯泡光电参数的测量方法
Methods for measuring electrical and luminous parameters of incandescent lamps
GB/T 15143-1994 管形荧光灯用交流电子镇流器一般要求和安全要求
A.C.supplied electronic ballasts for tubular fluorescent lamps-General and safety requirements
GB/T 15144-1994 管形荧光灯用交流电子镇流性能要求
A.C.supplied electronic ballasts for tubular fluorescent lamps-Performance
GB 15766.1-1995 道路机动车辆灯泡   尺寸、光电性能要求
Lamps for road vehicles Dimensional ,electrical and luminous requirements
GB/T 15766.2-1995 道路机动车辆灯泡  性能要求
Lamps for road vehicles Performance requirements
GB/T 15766.3-1995 道路机动车辆灯泡  辅助用灯泡
Road vehicle lamps for supplementary purposes
GB 16843-1997 单端荧光灯的安全要求
Single-capped fluorescent lamps-Safety specifications
GB 16844-1997  普通照明用自镇流灯的安全要求
Self-ballasted lamps for general lighting services-Safety requirements
GB/T 17262-1998 单端荧光灯  性能要求
Single-capped fluorescent lamps –Performance requirements
GB/T 17263-1998 普通照明用自镇流荧光灯  性能要求
Self-ballasted lamps for general lighting service-Performance requirements
GB 1312-1991 管形荧光灯座和启动器座技术条件
Technical requirements of lamphoders for tubular fluorescent lamps and starterholders
GB 1406-1989  螺口灯头的型式和尺寸
Types and dimentions of Edison screw caps
GB 1407-1996 卡口式灯头的型式和尺寸
Types and dimentions of bayonet caps
GB 1444-1987  防爆灯具专用螺口式灯座
Edison screw lampholders specially used for explosion-proof  luminaires
GB/T 1483-1989 螺口式灯头的量规
Gauge of Edison screw lamp caps
GB/T 1484-1979 插口式灯头的量规
Gauge of bayonet lamp caps
GB 2797-1994  灯头总技术条件
General specification for lamp caps
GB/T 2798-1981 圆筒式和凹式灯头的型式和尺寸
Types and dimensions of cylindrical and recessed  caps
GB/T 2799-1981  插脚式灯头的型式和尺寸
Types and dimensions of Pin caps
GB/T 2800-1981 预聚集式灯头的型式和尺寸
Types and dimensions of prefocus caps
GB/T 6997-1986  插脚式灯头的量规
Gauge of pin caps
GB/T 6998-1986  预聚集式灯头的量规
Gauge of  prefocus caps
GB 13260-1991  管形荧光灯座和启动器座型式和尺寸
Types and dimensions of  lampholders for tubular fluorescent  lamps  and starterholders
GB/T 13261-1991 管形荧光灯座和启动器座检验量规
Gauge of lampholder for tubular fluorescent lamps and starterholder
GB 17935-1999 螺口灯座
GB 17936-1999 卡口灯座
Bayonet lampholders
GB/T 3877-1983 钼箔
Molybdenum foil
GB/T 4181-1997钨丝
Tungsten wires
GB/T 4182-1997 钼丝
Molybdenum wires
GB/T 4183-1984  钼钨合金丝
Molybdenum- tungsten alloy wires
GB/T 4184-1984钨铼合金丝
Tungsten rhenium alloy wires
GB/T 4185-1984钼钨合金条
Molybdenum-tunsten alloy bars
GB/T 4186-1984钼钨合金杆
Molybdenum-tungsten alloy rods
GB/T 4187-1984钨杆
Tungsten rods
GB/T 4188-1984 钼杆
Mloybdenum rods
GB/T 4189-1984 掺杂钨条
Doped tungsten bars
GB/T 4190-1984 掺杂钼条
Doped molybdenum bars
GB/T 4842-1995纯氩
Pure argon
GB/T 5828-1995氙气
Xenon
GB/T 5829-1995 氪气
Krypton
GB 7447-1987 灯泡用氩气
Argon for glow lamp
GB 7448-1987 灯泡用氩气检验方法
Test methods of argon for glow lamp
GB/T 10624-1995 高纯氩气
High purity argon
GB 11248-1989 杜美丝
Dumet wire
GB 7000.1-1996 灯具一般安全要求与试验
General safety requirements and tests for luminaires
GB 7000.2-1996 应急照明灯具安全要求
Safety requirements of luminaires for emergency lighting
GB 7000.3-1996 庭园用可移式灯具安全要求
Safety requirements of portable lumiaires for garden use
GB7000.4-1996 儿童感兴趣的可移式灯具安全要求
Safety requirements of portable child-appealing luminaires
GB 7000.5-1996 道路与街路照明灯具的安全要求
Safety requirements of lulminaires road street lighting
GB 7000.6-1996 内装变压器的钨丝灯灯具的安全要求
Safety requirements of lulminaires with built-in transformers for filaments lamps
GB 7000.7-1996 投光灯具安全要求
Safety requirements for floodlights
GB 7000.8-1996 游泳池和类似场所用灯具 安全要求
Safety requirements for lulminaires for swimming pools and similar applications
GB 7000.9-1996 灯串安全要求
Safety requirements for lighting chains
GB 7001-1986 灯具外壳防护等级分类
Classification of degrees of protection provided by enclosures for luminaires
GB/T 7002-1986 投光照明灯具光度测试
Photometry for floodlight
GB 7256.1-1987 民用机场灯具技术条件  通用要求
Specifications for airport light fixtures  General requirements
GB 9316-1988 摄影用电子闪光装置安全要求
Safety requirements for electronic flash apparatus for photographic purposes
GB/T 9467-1988 室内灯具光度测试
Photometry of indoor type luminaires
GB/T 9468-1988 道路照明灯具光度测试
Photometry of luminaires for street  lighting
GB/T 9473-1988 民用台灯通用技术条件
General technical requirements of table lamp for civil use
GB 9720-1988 船用荧光照明灯具   通用技术条件
Fluorescent lights in ships-General specification
GB 11155-1989 船用指示灯通用技术条件
General specification for indicator light in ships
GB 12045-1989  船用防爆灯技术条件
Marine explosion-proof light-Specification
GB/T 13036-1991 可移式通用灯具技术条件
Technical requirements for portable general purpose luminaires
GB/T 13037-1991 固定式通用灯具技术条件
Technical requrements for fixed general purpose luminaires
GB/T 13954-1992 特种车辆标志灯具
Specical warning light for road vehicles
GB/T 13961-1992 灯具用电源导轨系统
Eletrical supply track systems for luminaires
GB/T 14076-1993 电影电视舞台灯具通用技术条件
General technical requirements of luminaires for film ,televisin studios and stage lighting
二、行业标准
QB 1113-1991 耐压照明灯泡
QB 1114-1991 高压氪灯管
QB 1115-1991 高压钠灯泡用电子触发器
QB1116.1-1991 仪器灯泡  白炽仪器灯泡
QB 1116.2-1991 仪器灯泡  仪器卤钨灯泡
QB 1116.3-1991 仪器灯泡  氘灯
QB/T 1494-1992 事物特性表  灯泡
QB/T 2048-1994 一般白炽灯泡总技术条件
QB/T 2050-1994 自镇流荧光高压汞灯泡
QB/T 2051-1994 荧光高压汞灯泡
QB/T 2052-1994 荧光高压汞灯泡用镇流器性能要求
QB/T 2053-1994 荧光高压汞灯泡光电参数测量方法
QB/T 2054-1994 局部照明灯泡
QB/T 2055-1994 装饰灯泡
QB/T 2056-1994 船用灯泡
QB/T 2057-1994 红外线灯泡
QB/T 2058-1994 照相灯泡
QB/T 2059-1994 照相放大灯泡
QB/T 2060-1994 反射型照相灯泡
QB/T 2061-1994 聚光灯泡及反射型聚光摄影灯泡
QB 2274-1996 电光源产品的分类和型号命名方法
QB 2275-1996 镇流器型号命名方法
QB 2276-1996 荧光灯用启动器
QB/T 3573-1999 电光源产品  图样的一般要求
QB/T 3574-1999 电光源产品  设计文件的编制方法
QB/T 3575-1999 电光源产品  工艺文件的编制方法
QB/T 3576-1999 电光源产品  图样及技术文件的更改规则
QB/T 3580-1999 高压钠灯光电参数的测量方法
QB/T 3581-1999 紫外线高压汞灯管
QB/T 3582-1999  紫外线高压汞灯管  紫外辐照度及电参数测量方法
QB/T 3583-1999 管形镝灯
QB/T 3584-1999 管形镝灯光电参数测量方法
QB/T 3585-1999 矿用头灯灯泡
QB/T 3736-1999 石英卤钨灯夹封部位温度的标准测量方法
QB/T 2450-1999 飞机灯泡
QB 1549-1992 插脚式灯座的型式和尺寸
QB 1550-1992 插脚式灯座的量规
QB 2218-1996 灯头、灯座的型号命名方法
QB 2219-1996 单端荧光灯灯头的型式和尺寸
QB/T 2220-1996 圆筒式灯头的量规
QB/T 2259-1996荧光灯用卤磷酸钙荧光粉
QB/T 2260-1996 灯用卤磷酸钙荧光粉相对亮度测试方法
QB/T 2261-1996 灯用卤磷酸钙荧光粉发射光谱及色坐标的测试方法
QB 3586-1999  插口式灯座技术条件
QB 3587-1999 螺口式灯座技术条件
QB 3588-1999 插口式灯座的型式和尺寸
QB/T3589-1999插口式灯座的检验量规
QB 3590-1999  螺口式灯座的型式和尺寸
QB/T 3591-1999 螺口式灯座的量规
QB/T 3733-1999 灯头温升的测量方法
QB 1112-1991 电光源玻壳型号的命名方法
QB/T 2049.1-1994  电光源玻壳  A型玻壳尺寸系列
QB/T 204.2-1994 电光源玻壳        B型玻壳尺寸系列
QB/T 2049.3-1994 电光源玻壳  BT型玻壳尺寸系列
QB/T 2049.4-1994电光源玻壳  G型玻壳尺寸系列
QB/T 2049.5-1994电光源玻壳  K型玻壳尺寸系列
QB/T 2049.6-1994电光源玻壳  M型玻壳尺寸系列
QB/T 2049.7-1994电光源玻壳  P型玻壳尺寸系列
QB/T 2049.8-1994电光源玻壳  R型玻壳尺寸系列
QB/T 2049.9-1994电光源玻壳  T型玻壳尺寸系列
QB/T 2049.10-1999电光源玻壳  ED型玻壳尺寸系列
QB/T 3577-1999 电光源玻壳通用技术条件
QB/T 3578-1999  电光源用玻璃管和玻璃杆
QB/T 3579.1-1999  电光源玻璃牌号命名方法
QB/T 3579.2-1999   DGB 421 型电光源玻璃主要技术数据
QB/T 3579.3-1999   DGB 422 型电光源玻璃主要技术数据
QB/T 3579.4-1999   DGB 423 型电光源玻璃主要技术数据
QB/T 3579.5-1999   DGB 431 型电光源玻璃主要技术数据
QB/T 3579.6-1999   DGB 432 型电光源玻璃主要技术数据
QB/T 3579.7-1999   DGB 433型电光源玻璃主要技术数据
QB/T 3579.8-1999   DGB 434 型电光源玻璃主要技术数据
QB/T 3579.9-1999   DGB 435 型电光源玻璃主要技术数据
QB/T 3579.10-1999   DGB 436型电光源玻璃主要技术数据
QB/T 3579.11-1999   DGB 437 型电光源玻璃主要技术数据
QB/T 2451-1999  DGB233型和DGW 240型电光源玻璃主要技术数据
QB/T 3734-1999 灯丝型号的命名方法
QB/T 3735-1999 绞合钨丝线圈
QB 1417-1991 防爆灯具安全要求
QB 1551-1992 灯具油漆层
QB/T 1552-1992 照明灯具反射器油漆层技术条件
QB/T 1553-1992 灯具瓦楞纸箱包装技术条件
QB/T 2134-1995 影视舞台用聚光灯具技术条件
QB/T 2135-1999 影视舞台灯具用单相三极插头插座和联接器技术条件
QB/T 2136-1995 影视舞台特殊效果灯(器)具技术条件
QB/T2137-1995 影视舞台用散光灯具技术条件
QB 3592-1999 手提灯
QB/T 3737.1-1999 民用、建筑灯具玻璃罩口径尺寸
QB/T 3737.2-1999 民用、建筑灯具玻璃罩罩座口径尺寸
QB/T 3738.1-1999  灯具型号命名方法  总则
QB/T 3738.2-1999  民用、建筑灯具型号命名方法
QB/T 3738.3-1999 工矿灯具型号命名方法
QB/T 3738.4-1999  公共场所灯具型号命名方法
QB/T 3739-1999  民用白炽落地灯通用技术条件
QB/T 3740-1999 灯具用软梗技术条件
QB/T 3741-1999 灯具电镀、化学覆盖层
QB/T 3742-1999 灯具木箱包装技术条件
QB/T 3743-1999 民用机场灯具技术条件   高强度立式下滑灯
QB/T 3744-1999 接地带灯技术条件
QB/T 3745-1999 跑道中线灯技术条件
QB/T 3746-1999 嵌入式灯具通用技术条件
GMT+8, 2026-11-3 13:04 , Processed in 0.463084 second(s), 32 queries , Gzip On.
