查看: 1123|回复: 4
[下载]:AutoCAD2005下载地址
发表于 2004-5-21 22:32:03 | 显示全部楼层 |阅读模式
http://www.downbar.com/SoftDown.asp?ID=712&lbID=0
可下,测试如下:
2004-05-21 22:09:31.539 正在连接 www.downbar.com:80
2004-05-21 22:09:31.849 正在连接 61.232.31.13:80
2004-05-21 22:09:31.989 已连接
2004-05-21 22:09:31.989 GET /SoftDown.asp?ID=712&lbID=0 HTTP/1.1
2004-05-21 22:09:31.989 Host: www.downbar.com
2004-05-21 22:09:31.989 Referer: http://www.downbar.com/SoftView/SoftView_715.html
2004-05-21 22:09:32.009 Cookie: zhao123=yes; linktopdownbar=yes
2004-05-21 22:09:32.009 Accept: */*
2004-05-21 22:09:32.009 User-Agent: Mozilla/4.0 (compatible; MSIE 5.00; Windows 98)
2004-05-21 22:09:32.009 Connection: Keep-Alive
2004-05-21 22:09:32.129 HTTP/1.1 302 Object moved
2004-05-21 22:09:32.129 Server: Microsoft-IIS/5.0
2004-05-21 22:09:32.129 Date: Fri, 21 May 2004 14:17:59 GMT
2004-05-21 22:09:32.129 Connection: close
2004-05-21 22:09:32.129 Location: http://hn-http.gd00.com/good/Autodesk.AutoCAD.2005.rar
2004-05-21 22:09:32.129 Content-Length: 121
2004-05-21 22:09:32.129 Content-Type: text/html
2004-05-21 22:09:32.129 Set-Cookie: ASPSESSIONIDACSADTQS=BJFJCAMDGDPNOGMEGHKLCFAP; path=/
2004-05-21 22:09:32.129 Cache-control: private
2004-05-21 22:09:32.129 重定向到 http://hn-http.gd00.com/good/Autodesk.AutoCAD.2005.rar
2004-05-21 22:09:32.129 正在连接 hn-http.gd00.com:80
2004-05-21 22:09:32.129 正在连接 202.103.86.56:80
2004-05-21 22:09:32.380 已连接
2004-05-21 22:09:32.380 GET /good/Autodesk.AutoCAD.2005.rar HTTP/1.1
2004-05-21 22:09:32.380 Host: hn-http.gd00.com
2004-05-21 22:09:32.380 Referer: http://www.downbar.com/SoftView/SoftView_715.html
2004-05-21 22:09:32.380 Cookie: ASPSESSIONIDACSADTQS=BJFJCAMDGDPNOGMEGHKLCFAP
2004-05-21 22:09:32.380 Accept: */*
2004-05-21 22:09:32.380 User-Agent: Mozilla/4.0 (compatible; MSIE 5.00; Windows 98)
2004-05-21 22:09:32.380 Connection: Keep-Alive
2004-05-21 22:10:32.386 超时
2004-05-21 22:10:32.386 等待 5 秒后重试
2004-05-21 22:10:37.393 正在连接 hn-http.gd00.com:80
2004-05-21 22:10:37.393 正在连接 202.103.86.56:80
2004-05-21 22:10:37.644 已连接
2004-05-21 22:10:37.644 GET /good/Autodesk.AutoCAD.2005.rar HTTP/1.1
2004-05-21 22:10:37.644 Host: hn-http.gd00.com
2004-05-21 22:10:37.644 Referer: http://www.downbar.com/SoftView/SoftView_715.html
2004-05-21 22:10:37.644 Cookie: ASPSESSIONIDACSADTQS=BJFJCAMDGDPNOGMEGHKLCFAP
2004-05-21 22:10:37.644 Accept: */*
2004-05-21 22:10:37.644 User-Agent: Mozilla/4.0 (compatible; MSIE 5.00; Windows 98)
2004-05-21 22:10:37.644 Connection: Keep-Alive
2004-05-21 22:11:37.650 超时
2004-05-21 22:11:37.650 等待 5 秒后重试
2004-05-21 22:11:42.657 正在连接 hn-http.gd00.com:80
2004-05-21 22:11:42.657 正在连接 202.103.86.56:80
2004-05-21 22:11:42.907 已连接
2004-05-21 22:11:42.907 GET /good/Autodesk.AutoCAD.2005.rar HTTP/1.1
2004-05-21 22:11:42.907 Host: hn-http.gd00.com
2004-05-21 22:11:42.907 Referer: http://www.downbar.com/SoftView/SoftView_715.html
2004-05-21 22:11:42.907 Cookie: ASPSESSIONIDACSADTQS=BJFJCAMDGDPNOGMEGHKLCFAP
2004-05-21 22:11:42.907 Accept: */*
2004-05-21 22:11:42.907 User-Agent: Mozilla/4.0 (compatible; MSIE 5.00; Windows 98)
2004-05-21 22:11:42.907 Connection: Keep-Alive
2004-05-21 22:12:42.914 超时
2004-05-21 22:12:42.914 等待 5 秒后重试
2004-05-21 22:12:47.931 正在连接 hn-http.gd00.com:80
2004-05-21 22:12:47.931 正在连接 202.103.86.56:80
2004-05-21 22:12:48.171 已连接
2004-05-21 22:12:48.171 GET /good/Autodesk.AutoCAD.2005.rar HTTP/1.1
2004-05-21 22:12:48.171 Host: hn-http.gd00.com
2004-05-21 22:12:48.171 Referer: http://www.downbar.com/SoftView/SoftView_715.html
2004-05-21 22:12:48.171 Cookie: ASPSESSIONIDACSADTQS=BJFJCAMDGDPNOGMEGHKLCFAP
2004-05-21 22:12:48.171 Accept: */*
2004-05-21 22:12:48.171 User-Agent: Mozilla/4.0 (compatible; MSIE 5.00; Windows 98)
2004-05-21 22:12:48.171 Connection: Keep-Alive
2004-05-21 22:13:05.246 HTTP/1.1 200 OK
2004-05-21 22:13:05.246 Server: Microsoft-IIS/5.0
2004-05-21 22:13:05.246 Date: Fri, 21 May 2004 14:08:42 GMT
2004-05-21 22:13:05.246 Content-Type: application/octet-stream
2004-05-21 22:13:05.246 Accept-Ranges: bytes
2004-05-21 22:13:05.246 Last-Modified: Mon, 12 Apr 2004 15:53:55 GMT
2004-05-21 22:13:05.246 ETag: "f2da5d5ca620c41:1521"
2004-05-21 22:13:05.246 Content-Length: 154553845
2004-05-21 22:13:05.246 开始接收数据
2004-05-21 22:26:53.046 线程完成在 30910769
2004-05-21 22:26:53.046 正在连接 202.103.86.56:80
2004-05-21 22:27:00.227 已连接
2004-05-21 22:27:00.227 GET /good/Autodesk.AutoCAD.2005.rar HTTP/1.1
2004-05-21 22:27:00.227 Host: hn-http.gd00.com
2004-05-21 22:27:00.227 Referer: http://www.downbar.com/SoftView/SoftView_715.html
2004-05-21 22:27:00.227 Cookie: ASPSESSIONIDACSADTQS=BJFJCAMDGDPNOGMEGHKLCFAP
2004-05-21 22:27:00.227 Accept: */*
2004-05-21 22:27:00.227 User-Agent: Mozilla/4.0 (compatible; MSIE 5.00; Windows 98)
2004-05-21 22:27:00.227 Range: bytes=118676311-
2004-05-21 22:27:00.227 Connection: Keep-Alive
2004-05-21 22:28:00.233 超时
2004-05-21 22:28:00.233 等待 5 秒后重试
2004-05-21 22:28:05.240 正在连接 202.103.86.56:80
2004-05-21 22:28:05.550 已连接
2004-05-21 22:28:05.550 GET /good/Autodesk.AutoCAD.2005.rar HTTP/1.1
2004-05-21 22:28:05.550 Host: hn-http.gd00.com
2004-05-21 22:28:05.550 Referer: http://www.downbar.com/SoftView/SoftView_715.html
2004-05-21 22:28:05.550 Cookie: ASPSESSIONIDACSADTQS=BJFJCAMDGDPNOGMEGHKLCFAP
2004-05-21 22:28:05.550 Accept: */*
2004-05-21 22:28:05.550 User-Agent: Mozilla/4.0 (compatible; MSIE 5.00; Windows 98)
2004-05-21 22:28:05.550 Range: bytes=118676311-
2004-05-21 22:28:05.550 Connection: Keep-Alive
2004-05-21 22:28:20.432 HTTP/1.1 206 Partial content
2004-05-21 22:28:20.432 Server: Microsoft-IIS/5.0
2004-05-21 22:28:20.432 Date: Fri, 21 May 2004 14:23:57 GMT
2004-05-21 22:28:20.432 Content-Type: application/octet-stream
2004-05-21 22:28:20.432 Last-Modified: Mon, 12 Apr 2004 15:53:55 GMT
2004-05-21 22:28:20.432 ETag: "f2da5d5ca620c41:1521"
2004-05-21 22:28:20.432 Content-Length: 35877534
2004-05-21 22:28:20.432 Content-Range: bytes 118676311-154553844/154553845
2004-05-21 22:28:20.432 开始接收数据
2004-05-21 22:29:06.698 线程完成在 120114610
2004-05-21 22:29:11.615 下载完成
发表于 2004-5-22 13:24:35 | 显示全部楼层
好啊!
谢谢你了  同志
发表于 2004-5-26 00:15:11 | 显示全部楼层
非常感谢,速度很快,谢谢
发表于 2004-5-26 01:44:40 | 显示全部楼层
能下,速度非常快!*-*2
发表于 2004-5-29 11:42:09 | 显示全部楼层
谢谢了
我找了老长时间
今天可是找到了
GMT+8, 2026-11-3 06:29 , Processed in 0.782521 second(s), 40 queries , Gzip On.
