查看: 891|回复: 3
[其他]:2004系列软件纷纷出笼
发表于 2004-5-22 00:26:39 | 显示全部楼层 |阅读模式
Bentley赶在它的全球用户大会前把2004系列的产品陆续在这几天都发布了出来,一下子select网站上好热闹
Uncertified Software ( DO NOT DISTRIBUTE )
Bentley InterPlot Server 2004 Edition - English  SELECT Released Products
Version  Applicable To  Date  File Size  Estimated Time
(56.0 Kbps)
08.05.00.33  N/A  20-May-04  21,790,378 bytes  51.9 minutes
Bentley InterPlot Professional 2004 Edition - English  SELECT Released Products
(56.0 Kbps)
08.05.00.33  N/A  20-May-04  98,140,793 bytes  233.7 minutes
Bentley Digital InterPlot 2004 Edition - English  SELECT Released Products
(56.0 Kbps)
08.05.00.33  N/A  20-May-04  145,674,855 bytes  346.8 minutes
Bentley InterPlot Client 2004 Edition - English  SELECT Released Products
(56.0 Kbps)
08.05.00.33  N/A  20-May-04  98,081,252 bytes  233.5 minutes
MicroStation PDF Composer 2004 Edition - English  SELECT Released Products
(56.0 Kbps)
08.05.00.33  MicroStation V8 2004 Edition 08.05.00.64 or higher  20-May-04  37,049,691 bytes  88.2 minutes
Bentley Publisher 2004 Edition - English  SELECT Released Products
(56.0 Kbps)
08.05.00.24  N/A  20-May-04  342,475,287 bytes  815.4 minutes
Bentley Architecture 2004 Edition - English  SELECT Released Products
(56.0 Kbps)
08.05.00.55  MicroStation TriForma 2004 Edition 08.05.00.64  20-May-04  66,928,902 bytes  159.4 minutes
MicroStation TriForma 2004 Edition - English  SELECT Released Products
(56.0 Kbps)
08.05.00.64  MicroStation V8 2004 Edition 08.05.00.64  20-May-04  56,772,705 bytes  135.2 minutes
Bentley ProjectWise 2004 Edition - Client Setups - English  SELECT Released Products
(56.0 Kbps)
08.05.00.79  N/A  20-May-04  127,918,097 bytes  304.6 minutes
Bentley ProjectWise 2004 Edition - Admin Setups - English  SELECT Released Products
(56.0 Kbps)
08.05.00.79  N/A  20-May-04  100,792,937 bytes  240 minutes
Bentley ProjectWise 2004 Edition - Server Setups - English  SELECT Released Products
(56.0 Kbps)
08.05.00.79  N/A  20-May-04  361,801,630 bytes  861.4 minutes
ProjectWise Server Setups - English  SELECT Released Products
(56.0 Kbps)
08.05.00.79  Bentley SELECTserver 2004 Edition 08.05.00.64  20-May-04  361,801,610 bytes  861.4 minutes
Bentley GEOPAK Rebar 2004 Edition - English  SELECT Released Products
(56.0 Kbps)
08.05.00.64  MicroStation V8 2004 Edition 08.05.00.64 or higher  19-May-04  51,222,324 bytes  122 minutes
Bentley GEOPAK Bridge 2004 Edition - English  SELECT Released Products
(56.0 Kbps)
08.05.00.64  MicroStation V8 2004 Edition 08.05.00.64 or higher  17-May-04  73,500,715 bytes  175 minutes
Bentley GEOPAK Survey 2004 Edition - English  SELECT Released Products
(56.0 Kbps)
08.05.00.64  MicroStation V8 2004 Edition 08.05.00.64 or higher  17-May-04  100,988,778 bytes  240.4 minutes
Bentley PowerSurvey 2004 Edition - English  SELECT Released Products
(56.0 Kbps)
08.05.00.64  N/A  17-May-04  290,139,530 bytes  690.8 minutes
Bentley PowerCivil 2004 Edition - English  SELECT Released Products
(56.0 Kbps)
08.05.00.64  N/A  17-May-04  261,560,584 bytes  622.8 minutes
Bentley GEOPAK Site 2004 Edition - English  SELECT Released Products
(56.0 Kbps)
08.05.00.64  MicroStation V8 2004 Edition 08.05.00.64 or higher  17-May-04  128,813,261 bytes  306.7 minutes
Bentley GEOPAK Civil Engineering Suite 2004 Edition - English  SELECT Released Products
(56.0 Kbps)
08.05.00.64  MicroStation V8 2004 Edition 08.05.00.64 or higher  17-May-04  174,449,659 bytes  415.4 minutes
Bentley Redline 2004 Edition - English  SELECT Released Products
(56.0 Kbps)
08.05.00.67  N/A  17-May-04  99,278,018 bytes  236.4 minutes
Bentley PlantSpace P&ID 2004 Edition - English  SELECT Released Products
(56.0 Kbps)
08.05.00.22  N/A  14-May-04  6,883,497 bytes  16.4 minutes
MicroStation Schematics 2004 Edition - English  SELECT Released Products
(56.0 Kbps)
08.05.00.22  N/A  14-May-04  8,117,080 bytes  19.3 minutes
Bentley GEOPAK Quantity Manager 2004 Edition - English  SELECT Released Products
(56.0 Kbps)
08.05.00.64  MicroStation V8 2004 Edition 08.05.00.64 or higher  13-May-04  29,493,260 bytes  70.2 minutes
Bentley MX Change 2004 Edition - English  SELECT Released Products
(56.0 Kbps)
08.05.00.79  MicroStation V8 2004 Edition 08.05.00.64
AutoCAD 2004
AutoCAD 2005
AutoCAD 2002  13-May-04  30,451,878 bytes  72.5 minutes
Bentley MX 2004 Edition United States - English  SELECT Released Products
(56.0 Kbps)
08.05.00.80  MicroStation V8 2004 Edition 08.05.00.64
AutoCAD 2002
AutoCAD 2004
AutoCAD 2005  12-May-04  150,669,685 bytes  358.7 minutes
Bentley MX 2004 Edition Australasia - English  SELECT Released Products
(56.0 Kbps)
AutoCAD 2002
AutoCAD 2004
AutoCAD 2005  12-May-04  179,134,335 bytes  426.5 minutes
Bentley MX 2004 Edition International - English  SELECT Released Products
(56.0 Kbps)
AutoCAD 2005
AutoCAD 2002
AutoCAD 2004  12-May-04  149,063,021 bytes  354.9 minutes
MicroStation Civil Extension 2004 Edition - English  SELECT Released Products
(56.0 Kbps)
08.05.00.64  MicroStation V8 2004 Edition 08.05.00.64 or higher  11-May-04  137,371,455 bytes  327.1 minutes
Bentley MX 2004 Edition Netherlands - English  SELECT Released Products
(56.0 Kbps)
AutoCAD 2002
AutoCAD 2004
AutoCAD 2005  11-May-04  181,391,736 bytes  431.9 minutes
Bentley MX 2004 Edition India - English  SELECT Released Products
(56.0 Kbps)
AutoCAD 2005
AutoCAD 2002
AutoCAD 2004  11-May-04  153,235,097 bytes  364.8 minutes
Bentley MX 2004 Edition United Kingdom - English  SELECT Released Products
(56.0 Kbps)
AutoCAD 2002
AutoCAD 2004
AutoCAD 2005  11-May-04  149,750,721 bytes  356.5 minutes
Bentley I/RAS B 2004 Edition - English  SELECT Released Products
(56.0 Kbps)
08.05.00.63  MicroStation V8 2004 Edition 08.05.00.64 or higher  07-May-04  13,248,430 bytes  31.5 minutes
GeoMacao - English  SELECT Released Products
(56.0 Kbps)
08.05.00.05  MicroStation V8 2004 Edition 08.05.00.64 or higher  07-May-04  36,304,572 bytes  86.4 minutes
Bentley PowerDraft 2004 Edition - English  SELECT Released Products
(56.0 Kbps)
08.05.00.65  N/A  06-May-04  133,851,491 bytes  318.7 minutes
(56.0 Kbps)
08.05.00.29  MicroStation V8 2004 Edition 08.05.00.64 or higher  05-May-04  37,009,771 bytes  88.1 minutes
Bentley Descartes 2004 Edition - English  SELECT Released Products
(56.0 Kbps)
08.05.00.61  MicroStation V8 2004 Edition 08.05.00.64 or higher  04-May-04  55,436,969 bytes  132 minutes
Bentley View 2004 Edition - English  SELECT Released Products
(56.0 Kbps)
08.05.00.64  N/A  04-May-04  62,348,756 bytes  148.4 minutes
Bentley SELECTserver 2004 Edition - English  SELECT Released Products
(56.0 Kbps)
08.05.00.64  N/A  30-Apr-04  7,149,845 bytes  17 minutes
Bentley InRoads Suite 2004 Edition - English  SELECT Released Products
(56.0 Kbps)
08.05.00.00  MicroStation V8 2004 Edition 08.05.00.64
AutoCAD 2004
AutoCAD 2002  29-Apr-04  109,296,249 bytes  260.2 minutes
MicroStation V8 2004 Edition Programming Documentation/ Examples - English  SELECT Released Products
(56.0 Kbps)
08.05.00.64  N/A  28-Apr-04  29,088,196 bytes  69.3 minutes
MicroStation V8 2004 Edition - English  SELECT Released Products
(56.0 Kbps)
08.05.00.64  Bentley SELECTserver 2004 Edition 08.05.00.64
发表于 2004-5-22 09:03:41 | 显示全部楼层
能否请大虾给出几个主要的模块的下载连接和那东北?
发表于 2004-5-22 09:59:22 | 显示全部楼层
谁能提供Redline的下载地址
发表于 2004-5-22 21:37:01 | 显示全部楼层
Bentley Redline V08.05.00.67  ( 2004 Edition )
ftp://ftp2.bentley.com/dist/sele ... n/rln08050067en.exe
GMT+8, 2026-11-4 01:36 , Processed in 0.539056 second(s), 38 queries , Gzip On.
