查看: 699|回复: 0
[LISP程序]:直接调用PhotoShop编辑图像[IMAGE]实体
发表于 2004-5-26 13:07:31 | 显示全部楼层 |阅读模式
点取图形内的图像[IMAGE]实体,自动打开PhotoShop编辑图像,在PhotoShop内完成后存盘退出,AutoCAD内IMAGE实体自动更新.
注意:使用PhotoShop时保持AutoCAD内警告信息框显示。关闭PhotoShop后再关闭AutoCAD内警告信息框
  1. (defun c:editimage (/ obj img path pdf)
  2.   (if (and
  3.         (setq obj (entsel "\n Select image in AutoCAD <exit>:"))
  4.         (setq obj (car obj))
  5.         (= (cdr (assoc 0 (entget obj))) "IMAGE")
  6.       )
  7.     (progn
  8.       (setq img (cdr (assoc 1 (entget (cdr (assoc 340 (entget obj)))))))
  9.       (if (null (setq path (vl-registry-read "HKEY_LOCAL_MACHINE\\SOFTWARE\\Microsoft\\Windows\\CurrentVersion\\App Paths\\Photoshop.EXE"
  10.                                              "Path"
  11.                            )
  12.                 )
  13.           )
  14.         (alert "Adobe Photoshop was not installed!")
  15.         (progn
  16.           (command "_.Undo" "_Group")
  17.           (entdel obj)
  18.           (command "_.Image" "_D" (vl-filename-base img))
  19.           (setq pdf (vlax-get-or-create-object "photoshop.application")
  20.                 opn (vlax-invoke-method pdf 'open img)
  21.           )
  22.           (alert (strcat "Image file was opened by Adobe Photoshop"
  23.                          "\nSwitch to Photoshop and modify the image."
  24.                          "\nSave Photoshop before close this alert!"
  25.                  )
  26.           )
  27.           (command "_.Undo" "_End")
  28.           (command "_U")
  29.           (if (= (type opn) 'vla-object)
  30.             (vlax-release-object opn)
  31.           )
  32.           (if (= (type pdf) 'vla-object)
  33.             (vlax-release-object pdf)
  34.           )
  35.           (setq opn nil pdf nil)
  36.           (gc)
  37.         )
  38.       )
  39.     )
  40.   )
  41. )
GMT+8, 2026-11-4 18:01 , Processed in 0.682892 second(s), 32 queries , Gzip On.
