查看: 1224|回复: 6
[原创]:Autodesk制造业解决方案(AIP9)全新出版
发表于 2004-6-3 13:13:38 | 显示全部楼层 |阅读模式
这套软件整合的东西可真不少。MDT好像已经被XXX掉了。可惜啊。等下载完后的第一时间内向大家报告。
Autodesk delivers a complete solution for manufacturers, including the most innovative 2D and 3D design tools and the only practical data management solution on the market. Working with Autodesk software, you’ll use design data to accelerate product development cycles, collaborate more efficiently with manufacturing partners, and, in the end, get better-quality products to market faster.
An Integrated Portfolio of Autodesk Design and Data Management Tools
Autodesk Inventor Series
Put simply, Autodesk Inventor® Series delivers the right tool for the job to help you design your entire product line. It is a comprehensive mechanical design software package that includes Autodesk Inventor for designing 3D parts and assemblies, AutoCAD® Mechanical for productive 2D drawing and documentation, and Autodesk® Vault to synchronize your design efforts. Because all these applications are integrated in a single package, Autodesk Inventor Series provides a risk-free path from 2D to 3D. Now you can move to 3D at your own pace with the assurance that you’re protecting your existing investments in 2D drawings and experience and working with the most compatible platform on the market. No wonder Autodesk Inventor Series is the world’s best-selling 3D mechanical design software.
Autodesk Inventor Professional
Start with the proven power of Autodesk Inventor Series, add a collection of highly specialized tools to design routed systems, validate parts, and import IDF files, and you’ve got Autodesk Inventor Professional. With virtual 3D models, it’s possible to check that all parts of an assembly—including tubing, piping, printed circuit boards, wire harnesses, and cables— will fit together properly.
AutoCAD Mechanical
Want to get unparalleled productivity out of your 2D mechanical design process? AutoCAD Mechanical can help you achieve that goal. This software accelerates mechanical design projects by automating common tasks. And it’s based on the AutoCAD® platform, so it offers all the DWG file compatibility your teams need to share design data with other AutoCAD and Autodesk Inventor users. But it extends the capabilities of AutoCAD to offer significant productivity increases in 2D mechanical design. Bottom line—this tool will save your teams countless hours of design and rework.
AutoCAD Electrical
Created by electrical control designers for electrical control designers, AutoCAD® Electrical automates key control system design tasks, so your organization can slash the chances of error, accelerate production cycles, and dramatically improve product quality. With benefits like these, AutoCAD Electrical is the only logical choice for electrical controls design.
Autodesk Vault
Make the most of your investment in design data with Autodesk Vault. This easy-to-use data management tool makes work-in-process data more accessible and reusable, while avoiding the versioning problems inherent in sharing files among workgroups. Most importantly, Autodesk Vault is integrated with Autodesk manufacturing design applications, so data management is easier and more efficient than ever.
Autodesk Streamline
The Autodesk Streamline® hosted project environment helps you share design data by integrating suppliers and vendors into a single extended manufacturing team for maximum project visibility and collaboration.
Autodesk DWF Viewer
Download Autodesk DWF™ Viewer free. This small application provides big benefits when you use it to view and print Design Web Format™ (DWF™) files, a fast, efficient way to distribute design data to anyone who needs it.
AutoCAD 2005
With AutoCAD 2005 software, you get productivity features like table objects and enhanced tool palettes to simplify drafting tasks. And the new Sheet Set Manager helps you create, manage, and share entire sheet sets with maximum efficiency.
AutoCAD LT
In the world of 2D design and documentation, productivity is crucial. AutoCAD LT® 2005 software helps you get more done in fewer steps, exchange native DWG data with project team members, and plot quickly and easily.
Autodesk VIZ
Explore design concepts and communicate design intent with Autodesk® VIZ 2005—the 3D modeling, rendering, and presentation software for developing compelling, realistic design visualizations.
Autodesk Consulting
Autodesk Consulting provides services that can help you streamline your business processes and get the best possible return on your investment in Autodesk technology.
Autodesk Subscription Program
Now there’s an easier way to protect your software investments. The Autodesk Subscription Program provides the most current design technology, web support direct from Autodesk, flexible self-paced training options, and a broad range of other technology and business benefits.
发表于 2004-6-3 20:34:49 | 显示全部楼层
真的不少!好象ADT也不在里面
发表于 2004-6-24 14:25:00 | 显示全部楼层
看样用ADT的人要转向用AIP了
发表于 2004-7-4 23:04:50 | 显示全部楼层
那裏可以下載,請告訴一下。我很有興趣。謝謝!
发表于 2004-7-8 20:22:57 | 显示全部楼层
不要
发表于 2004-7-15 14:49:26 | 显示全部楼层
这么长,还是英文的,头疼
发表于 2004-7-16 17:16:46 | 显示全部楼层
就是靠软件多取胜。
软件再多没有实用性还不是等于0
GMT+8, 2026-11-3 06:04 , Processed in 0.504302 second(s), 44 queries , Gzip On.
